Expert
- Posted on Jul 11, 2009
Re: It will not drain. every thing else seems to work...
The problem is probably the pump being clogged with an object. Typically it is a coin.
Remove the front bottom cover to access the pump. Remove the two hoses. Make sure you have a pan to catch the water from the hoses. You will be able to remove the objects after the hoses are removed
Either water pump failure or depending on setup, broken pump belt
