Garden Logo
Jenifer Mott Posted on Apr 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why will my riding mower loose power when going forward after about 50 yards of mowing. I can push the clutch in and it will go again. Help!
Behind_Blue_Eyes
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 1,727 Answers
  • Posted on Apr 28, 2015
Behind_Blue_Eyes
Master
Level 3:
Renaissance:
Answers
1727
Questions
0
Helped
455093
Points
3267
Did you check the drive belt ???
5 Related Answers
Anonymous
  • 57 Answers
  • Posted on May 18, 2009
SOURCE: My riding mower is stuck in gear. I can shift
If the wheels aren't facing straight forward you may have broken an axle.
Anonymous
  • 59 Answers
  • Posted on May 27, 2009
SOURCE: Mower will not stop when clutch is depressed
When you replaced the belt you either got a shorter belt or you have rerouted the belt wrong. You might try and get an original; belt and replace the one on the tractor. Good Luck-David
Hiram Sims
  • Posted on Sep 03, 2009
SOURCE: Murray Riding Mower will not move forward or back
my murray Riding Mower will not move forward or backward
rtpflh
rtpflh
  • 546 Answers
  • Posted on Sep 28, 2009
SOURCE: I have a troy bilt riding mower, 6 years old, 26
many of these units use the starter motor as the generator to re-charge battery. check voltage regulator & wiring.
Anonymous
  • 148 Answers
  • Posted on Oct 15, 2009
SOURCE: craftsman riding lawn mower steering shaft fell.
Look under the seat of your tractor and note the complete Model number.
(usually begins with 917. _ _ _ _ _ _ )
Next, go to THIS PAGE and use the Model Number to find an exploded view of the steering components and how they assemble.
Hope this helps,
Dolf-
Toro riding mower stopped moving
If you have no forward, no reverse but the motor is still running normally the most likely reason for this is the main drive belt. This connects the motor to the transmission. If it stretches, breaks or drops off the drive pulleys you will lose all movement.
Aug 21, 2023 • Toro Garden
Worx mower. I was mowing fine..stopped to change bag.. Wouldn't restart when pushed the key button. handle engaged and it would power move forward. Engine would not start.battery fully charged
sounds like, a valve clearance adjustment problem. starts when cold, looses some power when hot, if turned off or stops, won't restart until cold.
Aug 04, 2015 • Garden
Yard machines rider mower would not go back or forward, speed gears not engaging
Yard machine mowers are notorious for the shifter linkages getting bent or loose, it sounds like it's not engaging correctly and that you may need to get under it and see if anything is loose or obstructing that linkage. I know mine has that issue every season, the first thing I do is get under there and make sure everything is good to go, I tighten up the linkage and then I check the tension on the belts.
The next time you fire it up, push the clutch in all the way, apply gentle pressure to the shifter for forward and back, and then let off gently on the clutch until it pops into gear and begins to move. If you can't get it to do it that way, then I'd say you need to replace the drive belt or adjust it.
I have a John Deere LA145. It has 50 hours on it. I mowed the yard with it and then it wouldn't back up with the blades engaged and the rio button pushed. I turned off the PTO button and backed
With everything you said I never heard you say you checked the oil or put in oil Hope it didn't run tight on you.I'm not sure if your model has one but some also have safety switches under the clutch pedal . If not have you checked the hydrostatic oil im not sure if your is hydro but that could also keep it from shifting in gear and possibly keep it from starting to protect transmission. Just some ideas good luck
YARD MACHINE WILL NOT GO FORWARD OR REVERSE
Hi, did this happen while mowing or after parking up? Let me know the circumstances and I will try and assist. Regards Phil
3helpful
2answers
Top Garden Experts
Jay Finke
Jay Finke
john h
