Does it still make ice cubes??? If yes then its not the filter. It may be one of these problems. !/2 the water inlet valve may be defective. 1/2 is for the icemaker the other 1/2 is for the water dispenser. Some companies have had problems with the water line inside the freezer door actually freezing up. Is some cases a heater kit is required to be installed in the door dispenser area. With out a brand/model number I can't be more exact.
I appreciate your inquiry, bela_desousa!
From the information you have provided the water dispenser on your Frigidaire refrigerator is not dispensing. Have you recently changed your water filter? If you water filter has not been changed and is dirty or clogged it could lead to potential failure of your water dispenser. If the filter has been changed it could be a faulty dispenser. I would suggest consulting with a professional technician for proper diagnosis and repair. Hopefully this is helpful. -Matt
