Swisher Zt2560 Zero Turn Radius 60" Riding Mower Logo
T
Taylor Graham Posted on Apr 10, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you replace the top belt? The one directly beneath the engine? As far as I can tell, there's no way to get to it.
Eugene Rounds
Level 3:
  • Swisher Master 1,169 Answers
  • Posted on Apr 10, 2015
 Eugene Rounds
Swisher Master
Level 3:
Answers
1169
Questions
Helped
592238
Points
4432
You remove the Pto clutch assy then you replace drive belt as that pulley would then down and off.
Will it hurt my engine if the timing belt breaks
Absolutely can. Depends on the engine. Tolerance or no tolerance? Depends on who you had look at it. Most good mechanics will tell you have much time you have on a belt. shops will tell you it needs replaced now.
Qualcast rm34 assembly
I'm not familiar with the Qualcast rm34 assembly, BUT... from the "smoke" from beneath, I suspect that something has jammed/locked the blades, or blade pulleys, and the resulting slippage of the belt is causing the smoke.
With engine off, AND the spark plug wire FAR REMOVED from the spark plug, CLEAN OUT ALL DEBRIS FROM beneath the deck, above deck, AND from all areas in contact with the belt!
May 04, 2014 • Garden
1helpful
My washer wont spin or agitate and there was a burning smell
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
To replace the belt carefully pry up on front washer top to release plastic keeper pins, remove 2 Phillips screws from beneath lower front washer panel, slightly lift upward on panel to release. Now remove old broken belt, push new belt beneath large tub pulley and put belt on small motor pulley. After this push back belt tension /idler arm, start belt on large tub pulley, turn tub pulley by hand to run belt on, release tension on idler arm. Replace front panel and lower top.
Hope this helps... Please post back if you need more information.
Daniel
How do I change the belt on a dirt devil ultra vision vacuum cleaner
I just changed mine and I will be blunt. First off, the design is **** on this vacume, secondly the belt was designed to break on the rusty carbon steel pully rod. Ok now that I've vented we will get down to business. On the bottom of the vacume you will find a plastic housing thats covering the brush. It will have 4 screws around the brush plus one above them. The housing itself is shaped like an L. Remove all the screws and expose the bare brush. This was not my case but there should be a belt holding the brush to a small steel pully rod in the top part of the L indention. If not then just locate an indention on the brush where the belt will be placed and look directly beneath that to find the pully rod (probably about 6 inches beneath the indention on the brush). wrap your new belt around the metal pully rod and then take out the brush. Wrap the other end of the belt around the indention on the brush and pull up hard and replace the brush in its vacume housing. This will take some effort as the belt has to be stretched. When finished replace the housing cover with the five screws and boom you're done.
1helpful
Load was to heavy and I smelt burnt rubber now no spin
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
Please check this diagram for the part number F28(drive belt)--
Please post back for any further assistance.
Thanks
Daniel
1helpful
2answers
The belt dry rotted and flew off without me being able to remove it myself, now I need to know how to install the new drive belt.
To install the drive belt you will have to remove the drive belt first.
Follow the procedure: ---
Park the tractor on a level surface. Set the parking brake and remove the key from the ignition. Study the belt replacement guide decal located underneath the left foot board for proper belt routing instructions.
Remove the mowing deck by first moving the attachment clutch lever to the disengaged position (toward you). Move the attachment lift lever all the way forward to lower the mower housing to its down position.
Crawl beneath the tractor and roll the drive belt off engine pulley (it hangs directly beneath the engine). Remove small retainer clip that holds the clutch spring to the pulley bolt located at the center of the mowing deck. Remove the large retainer springs (two of them), then slide the belt collar away from the mower housing and off the housing bracket.
Disconnect the anti-sway bar rods from the chassis brackets by removing the retaining cotter pins. Disconnect front links from the mower deck by removing retaining cotter pins. Disconnect the suspension arms from the rear mower deck brackets by removing the two cotter pins.
Move the attachment lift lever all the way to the forward position to raise the mower suspension arms to the full up position. Slide the mower deck out from beneath the tractor.
Crawl beneath the tractor and roll the drive belt off of the stationary idler pulley and the clutching idler pulley. They are both located immediately adjacent to the engine pulley. Be sure the belt is already away from the engine pulley, as well.
Push the drive belt slack toward the rear of tractor. Remove the drive belt from the Trans axle pulley by taking it over the trans axle pulley while compressing the movable belt keepers surrounding it. Remove the old belt from the tractor by pushing it clear of the center span keeper (located beneath the Trans axle pulley).
Install a new drive belt by following the reverse of the instructions for removal. Test the tractor and mower for normal operation.
 Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jul 19, 2010 • Garden
23helpful
Belt diagram 1997 toyota corolla? alternator belt replacement?
The 97 Corolla has three accessory belts. The alternator belt is the one you see when you look down on the passenger side standing near the front of the engine compartment. If fits over the alternator and the engine pulley. The belt beneath it is the a/c belt (if the car has a/c). It fits over the engine pulley and the a/c compressor. The power steering belt is toward the rear of the engine compartment, on the same side. It fits around the engine pulley and the power steering pump.
Replacing the alternator belt is not too difficult. Standing in front of the car and facing towards the rear, loosen the locking bolt under the right side of the alternator. Then loosen the alternator hinge bolt on top of the alternator. Now you are ready to loosen the alternator belt tensioner adjustment bolt, accessed under the alternator from the front. Turn the tensioner until the old belt is loose enough to remove, then turn it further so that the new belt will go on easily. Replace the belt and re-tension until you have about 1/4 in. to 1/8 in. of play in the belt, tighten the lock bolt and the hinge bolt, and run the engine. If the belt squeals it means you need more tension, but do not overtension. Recheck it after a few days.
7helpful
I am going to replace the camshaft sensor and can't find it's location
While facing the engine from the front, you will see on the left hand side the power steering pump. The pump is secured to the timing cover using three 13mm headed bolts accessed thru the holes in the pulley. Of course you will have to remove the belt first. It can be tricky to remove the pump from the mount, and position it to the side. The cam sensor is located directly beneath the pump. It has a 3 wire pigtail coming off it that leads to a connector usually located at or near the top of the intake.
Baught belt - need to know how to chane it
YOU HAVE WHATS CALLED A TENSIONER PULLEY IN FRONT OF ENGINE , ONE OF TWO PULLEYS THAT ARE SLICK (NO GROOVES). THE TENSIONER PULLEY IS WHAT YOUR AFTER. IT WILL BE ATTACHED TO A SLOTTED BRACKET WITH A BOLT HEAD DIRECTLY BEHIND IT.(LOOKING AT ENGINE FROM FRONT OF VEHICLE ITS USUALLY ON YOUR FAR RIGHT!) FIRST UNLOOSEN BOLT ON FRONT OF PULLEY ABOUT FIVE TURNS , THEN MOVE TO BOLT ON TOP BEHIND PULLEY , AND START UNLOOSENING IT TILL PROPER TENSION IS RELEASED TO SLIDE BELT OVER ALL PULLEYS(USE BELT DIAGRAM UNDER HOOD FOR PROPER INSTALLATION. ONCE BELT IS ON REVERSE STEPS 1 AND 2. TIGHTEN TOP BOLT BEHIND TENSION PULLEY TILL BELT HAS ABOUT A QUARTER INCH PLAY IN IT UP AND DOWN (DON'T OVER TIGHTEN).THEN TIGHTEN FRONT PULLEY BOLT TILL VERY SNUG.YOUR DONE! BELT MAY NEED RE-TIGHTENED AFTER DRIVING A FEW DAYS , BUT YOUR AN EXPERT NOW AND THAT WON'T BE A PROBLEM. HOPE THIS HELPED!
2helpful
2002 Mitsubishi Lancer
cant tell u how to replace the belt its eith in the engin or on the sidewith a cover over timing belt that is.. to set timinmg when your pistons are fully at top of engine turn back 1/8 of a turn right bf top dead center.. valve chould be closed on 1first clyder if not then this means your on the second strock..has to be on first stroke..turn over again then set piston at top with valve closed..your cam should fall in place..note if u remove the cam MAKE SURE U MARK THE CAP TO THE POSTION AND DIRECTION YOU TOOK IT OFF>> if not you will end up with a warped cam and rod caps wore and warped..
Top Swisher Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Swisher Garden Expert? Answer questions, earn points and help others
