Can the kelvinator k600 washing machine heat water?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,003 Answers
If the rating plate is around 3KW, then it has a heater installed.
Posted on Apr 08, 2015
6ya staff
SOURCE:
prem mathew
  • 1294 Answers
SOURCE: User Manual required (Kelvinator Washing Machine)
Click on Bosch or your brand (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
Posted on Dec 26, 2007
Fahr Quad
  • 736 Answers
SOURCE: MY KELVINATOR KL15TL WASHING MACHINE DOES NOT
I can think of three possible causes. The first is the timer not advancing to the wash cycle. Try manually advancing the timer and see if it will start. The second possibility is the drive motor or drive belt. Open the access panel to see if the belt is intact, then see if the motor starts when you manually advance the timer to wash. The third possibility is the lid switch. You can usually get to it by inserting a putty knife in the two from corners to pop the spring clips open, and the top flips back.
Posted on Aug 20, 2009
mnwarfield10
mark warfield
  • 452 Answers
SOURCE: how to replace the water inlet
TURN ELECTRIC OFF .....top lid off x2 screws on lid....remove water inlet pipe...TURN WATER OFF FIRST :)....undo or unclip on valve...unclamp water clamp on hose ... take off hose ...reomove valve..refit new part ..refit hoses .... test .
Posted on Jan 04, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: do you have the manual of the kelvinator washing machine 380 ?
www.diplodocs.com
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
fuda1
SOURCE: my kelvinator k600 top loading machine fills and
the belt has cutting
Posted on Aug 23, 2011
My Kelvinator K600 Washing Machine sometimes does not operate on the Spin Cycle
Spin clutch soliniod not engageing underneath (replace).
Oct 02, 2016 | Washing Machines
I have just reeived a Kelvinator dishwasher KD12WW. I have only a cold water outlet can I still wash with it
I found a site that is important for you to down load the site is ns323666.ip-37-187-156.eu
It is a pdf version of the instruction manual for the dishwasher
I notice that one of the instructions is quote" when using your dishwasher , you should prevent plastic items from contacting the heating element" un quote
most all dishwashers heat their own water above what human hands can stand so from that statement you can use cold water inlet only and the machine will heat it to operating temperature
I got that site by going google and typing in --kelvinator kd12ww dishwasher
then I selected site manual-kelvinator kd12ww dishwasher clicked on that and that address came up with the pdf manual
there are other sites that have parts manuals and heaps of other information
call your local kelvinator service agent and ask them about a heating element
Sep 30, 2016 | Kelvinator Dishwashers
Kelvinator 085 Smart Drive. Why won't it start?
kelvinator smart drive 085 washing Questions & Answers ...
www.fixya.com > Forum > Tags
smart drive 085 not filling with water when start button depressed Could be the magnetic latch on the lid that tells the machine when its closed you can by pass
Sep 30, 2015 | Washing Machines
Washing machine doesnt work kelvinator smartdrive 085 0.5kg
you have to check 1- water pressure switch (wps) , 2- the hose which fixed between wps and drum may disconnected or broken.
Jun 12, 2017 | Kelvinator Washing Machines
My Kelvinator K600 drains as it fills. Possible cause?
Drain hose too low Gravity is pulling out the water as fast as it fills. All washers have this same problem. The hose must be at least 30 inchs above the floor. Sudsing detect possibly?
See page 48
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 12, 2011 | Kitchen Ranges
How to replace the water inlet in electrolux kelvinator 760 FXZ washy talky washing machine
Jan 04, 2010 | Washing Machines
Kelvinator Washing Machine has no power
unplug the washer and plug something else you know works in to make sure you have power in the outlet if not
check your circuit breaker box and reset the switch that is not lined up with the others flip it on off on
Now check the washer If you haven't already done this.
Some units have there own fuse in the back , if so it will be labeled.
hope this helps if not get back to me mike
Jun 11, 2017 | Washing Machines
Washing Machines Logo
76 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
