This has occured ever snce i tried to blend thick hummus in it. When it fuses the whole kitchen also fuses.
I'm having the same problem with my Vitamix Super 5000. I just found this fix online, and although I haven't used it yet myself, all the comments indicate that it's the way to go to fix this problem. Hope the link helps:
http://uppityairlinepilot.blogspot.com/2012/09/vita-mix-5000-variable-speed-fix.html
I would suspect a motor fault, most likely an insulation problem in the armature or the fields. Contact Vitamix for your local authorised service agent. Unless it has been assembled incorrectly it should not be one of the internal wires as they are supposed to be secured and correctly routed during assembly.
