Frigidaire ATF6000ES Front Load Washer Logo
Posted on Jul 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Frigidaire Gallery Front Loader Won't Spin...
Fills up with water no problem and then stops and will just make a click sound but doesn't do anything else but "click" from then on.
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jul 11, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
Helped
3441
Points
12
I posted on another question, I found that the problem was that the housing for the switch control was loose, as it did not snap shut. If you remove the lower panel and jiggle the wires, you may find that the problem goes away. This still points to loose connections in the control switch. I removed the switch wire assembly, having to cut the rubber "boot" near the door and taped the plastic housing shut. The problem appears to be that the drum, during the course of washing, would bump this plastic housing and cause the wires to become loose.
J. Bradshaw
Level 2:
Sniper:
  • Expert 121 Answers
  • Posted on Jul 10, 2009
J. Bradshaw
Expert
Level 2:
Sniper:
Answers
121
Questions
Helped
87654
Points
323
The motor have froxze up. First make sure the belt has not broke. Remove the rear cover and you will be able to access the motor and belt.
1 Related Answer
Anonymous
  • 4 Answers
  • Posted on Mar 20, 2010
SOURCE: washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Why does my Frigidaire Gallery Front loader washing machine not spin?
Hello Friend, thank you for your inquiry!
I interpret from what you have described that your Frigidaire washer possibly has a faulty bearing or something may be lodged between the inner and outer drums. This is not a typical do-it-yourself job. Personally, I would recommend reaching out to a qualified appliance repair person who will be best able to pinpoint the exact problem. I hope this information helps to some degree. - Z
My 10+ yrs old Frigidaire gallery # GLTF1240AS front-loader drum won't agitate/spin
Check and see if the drive belt broke? On mechanical agitators using gears, a solenoid may fail and drive motor won't function.
2helpful
Washing machine won't spin and drain
Frigidare Gallery 2 speed top loader fills with
It could be multiple problems, if so it's more than one of the below, it would be cheaper to buy a new unit.
Start by removing the front panel and check the belt and idler pulley/tensioner. Look for wear in both and make sure there isn't too much play (it should only move about a 1/2 inch when pushed on it's longest stretch. While you have the front open, inspect the pulley for damage or excessive play.
Another cause could be the transmission (it's just above the pulley). Look for fluid/oil leaks and/or rust. A bad oil leak can cause the transmission to seize up. If you notice rust accumulated on the transmission assembly, you probably have a bad seal. Water could have gotten in there causing it to fail. A damaged transmission needs to be replaced, repair parts are not available.
The cycling problem sounds like a faulty timer. Test it by advancing the dial and make sure the correct cycles are starting/stopping. This part can be replaced with a few simple tools.
As always, make sure you disconnect the power before doing any service.
1helpful
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Frigidaire Front Loader Won't Drain
if your washer is digital or with elecronic control board check the the motor control board located at the bottom difiniely you have to call a tech to confirm that. other model like wd5595 and wd 8095 has the same problem and it is the motor control unit that always fails.
2helpful
2answers
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
