You have set that item to be linked to a condiment/ prep PLU which means you set the wrong digit during tax linking. go back and turn the condiment/ prep PLU feature off
this has been a problem with my "internet
navigator logitech keyboard" and when i run the "#keyhistory" script i
get these results after hitting
the following keys :
L L RightShift L L CapsLock L L
VK SC Type Up/Dn Elapsed Key Window
4C 026 d 0.47 L
4C 026 u 0.16 L
4C 026 d 2.89 L
4C 026 u 0.17 L
A1 136 d 2.19 RShift
A6 16A a d 0.02 Browser_Back
A1 136 u 0.16 RShift
A6 16A a u 0.00 Browser_Back
4C 026 d 0.80 L
4C 026 u 0.13 L
4C 026 d 2.52 L
4C 026 u 0.14 L
14 03A d 6.05 Caps Lock
AA 165 a d 0.02 Browser_Search
14 03A u 0.19 Caps Lock
AA 165 a u 0.00 Browser_Search
4C 026 d 4.80 L
4C 026 u 0.14 L
4C 026 d 0.11 L
4C 026 u 0.14 L
and as you can see I have two problems with this. One problem is that
when i am in an internet browser and i hit shift it acts as
Backspace/Back and when i am renaming a folder and i hit shift to use
caps it also acts as Back. The other problem is similar with the Caps
Lock key, whenever i am in an internet browser and i hit Capslock, the
Search window appears and the Capslock function gets activated as well.
I was trying to Remap these two keys but i wasn't successful in doing so,
for the shift key i tried remaping 00_6A and E0_6A to another key and i
also tried remapping 00_36 to another key and neither of these two
helped.
and for Caps lock i tried remapping E0_65 to another key and it didn't
work. I also tried turning off both the shif key and the CapsLook key
and their that only turned off their original function but it didn't
turn off the backspace or the search functions.
If this is a Chrysler radio , then please check the Serial Numbers again as
T Q1 AA 026 0 A6 09 is incorrect. It should have at least one more digit at the end of it.
the Xerox error code 026-714 means that the printer cannot access a remote proxy-server. if the printer has been configured to use this remote proxy instead of your local one (or none at all), none of the mentioned network functionalities will work supposedly.
When you right-click a file, Windows Explorer may quit unexpectedly, or you may receive an "Access Violation" error message, or you may receive the following error message:
Windows Explorer has encountered a problem and needs to close. We are sorry for the inconvenience. When you view the details of the error, you find an error signature similar to the following:
AppName AppVer ModName ModVer Offset --------------------------------------------------------------- Explorer.exe 6.0.2800.1221 Ntdll.dll 5.1.2600.1217 00054084
After you install Windows 2000 Service Pack4 (SP4) or the 823980 security patch (MS03-026) documented in MicrosoftKnowledge Base article 823980, you may not be able to open .max or .drffiles in the following products:
