SOURCE: How do I take pictures from my memory and put them on my SD card?
You'll have to buy the charger/station for S5. No other cord fits your nikon unfortunately.
SOURCE: nikon d40x issues with memory card
Sounds like the locking mechanism for your memory card is broken or defective. The only people qualified to fix that would be Nikon.
If it is still under warranty, let them know the situation.
If not, it will be around $200 to fix.
SOURCE: Can I transfer pictures from my Nikon Coolpix L12
Hi,press to see pixs, then menu- you will see playback menu>look for Copy, press ok> you will see from camera to card & from card to camera. Just press ok and that's it. It works. Nil
SOURCE: i have nikon camera dx100
Ladz215,
You didnt really say if the card was in your camera when you took the pictures, so I will try and walk you through a couple scenarios....
If the same card WAS in the camera when you took the pictures, and it worked OK until you took it out and re-inserted it, you can try a couple of different things. First off, by no means format the card! Look at the card contacts. If they are dirty, try wiping them gently with a clean cotton cloth (make sure it is cotton so you do not "zap" the card with static!) and some isopropyl (rubbing) alcohol- use it sparingly- put a little on the cloth- don't pour it on the card! Let it dry for a few minutes and try again. If you have some "canned air" you can blow out the camera slot also. With the card in your camera, also try connecting the USB cable to your PC and see if you can download them. If this does not work, look and see if you have a card slot in your PC or printer and see if you can read it that way. Another alternative is taking the card to the photo shop of your local Walgreens, CVS, Rite-Aid, or any other store with a photo shop....nearly all have card readers now.
If the card was not in your Nikon when you took the pictures, or if the card was not initially formatted, they will be in the cameras native memory. Connect the camera to your PC with the USB cable and you will be able to retrieve them. Normally without a card or if the card was not formatted before it is used, the camera is capable of holding about 35 pictures in its native memory.
When you are done, make sure to format your card so it will work in the future. Follow the menu instructions.
Good Luck! Thank You for using FixYa.
