Original Timex® Replacement watchbands and straps designed to fit Casio, Seiko ... Currently the Timex bands we have are below. Leather Timex Watch Bands.
I've been looking for a replacement for the Seiko SNAE93p1 and have seen the replacement for this in several places. I only remember because it has a red and black band similar to the one on the watch I'm wanting, and I figure that I should get a replacement band when I buy this new watch, as the synthetic bands on Seiko watches tend to break after about 3 years or so.
Watchbands.com has it for $65 I believe. watchbands com
My son's watch (WR 50M) broke... so I have a strap, if you'd like it. He loved this watch and it would cost about the price of a new one to repair, so I'm buying him a new one. He's had the same watch for years... bless, huh? If you anywhere I can purchase another WR 50M - 1440 Timex, I'd be most grateful.
Take the watch with the broken watchband and place it on the table. With a ruler, measure the width of the broken band at the point where it is attached to the watch. Now, measure the total length of the watchband when it is in one piece and fits around your wrist. There will be a crease on the band where it is normally buckled.
Step 2
Go to the local store and select a band that you like. You should make sure that the width of the band at the point of attachment to the watch is the same as the old band. Also make sure that the new band will be long enough and not too long to fit your wrist. Purchase the band and return home to change the band.
Step 3
Clear a spot to work and make sure that there is a small towel covering the table top so that you can see anything that may drop or pop out during the process of changing the band.
Step 4
Use a magnifying glass to look at the point where one side of the band is attached to the watch. You will see a small pin connecting the band to the watch on either side of the band. Carefully use the jeweler's screwdriver to depress the spring loaded pin from the watch to the band and release it from the watch. When the tension on the spring pin is released it may pop out of the band and you will want to take care not to lose it. Repeat this process with the other half of the band.
Step 5
Take the new band and slip the spring pins into the small holes on the end of the band where it will attach to the watch. Working with one end at a time, slip one side into the pin hole in the watch body.
Step 6
Use the jeweler's screwdriver to depress the other side of the spring pin and guide it into the pin hole in the other side of the watch body. Repeat this process with the other half of the watchband and other spring pin. You now have a new band for your broken one.
Put the watch face down and examine the point where the band is connected to the watch case. you will find two holes and through them you will see sprinbar ends insertyed into watch case lugs. Take the tiny screwdriver and push the springbar end inwards,then do the same at the other lug reaching them through those holes. Then repeat the same at the other end of the band. Measure the distance between watch case lugs- this will be exact size for your new leather band.
Here is the form used to contact lacrosse for a watchband;
http://www.lacrossetechnology.com/watchband_form.pdf
or you can use;
http://www.lacrossetechnology.com/support/contact.php
Here is the user guide for your watch if you need it;
http://www.lacrossetechnology.com/k2100/manual.pdf
Hope this helps :)
