Ovens Logo
M
MR Ian Jewell Posted on Mar 21, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Removal and replacement of heahign elements - DeLonghi Ovens
Todd Arndt
Level 3:
Top Expert:
  • Master 2,044 Answers
  • Posted on Mar 21, 2015
Todd Arndt
Master
Level 3:
Top Expert:
Answers
2044
Questions
Helped
584204
Points
5934
They are replaced from Underneath. You lift the glass and metal frame TOGETHER and then you will gain access to the Element. The Glass and the METAL FRAME are together so you unscrew them and it lifts. It is Hinged in the BACK
2answers
Teka ht -710 me
How do I replace the bottom oven element on a teka ht 710 me oven
Jan 15, 2014 • Ovens
tip
OVEN ELEMENT NOT WORKING/HEATING TEST IT
<p>Hello,<span> </span><br /> <p> <br> <p>I understand that you oven element is not heating up.<br> <p> <br> <p>The easiest way to tell if it is the element is to check the element itself you will need a few tools to do this one of which is a <b>multi meter with continuity</B>.<br> <p> <br> <p><b>Testing Element:</B><br> <p> <br> <ol> <li><b>Shut off power</B> to the unit this can be accomplished by flipping the breaker or unplugging the unit from the wall.</LI> <li>Remove the rear panel of the Range (on freestanding ranges), on wall ovens you may be able to remove the screws that hold the burner in place at the back and pull the element and wires forward (Be careful not to let the wires go back in side the wall as you will have to pull the oven out to reconnect the element)</LI> <li>Remove the wires that are attached to the terminals on the element </LI> <li>Use your continuity tester and place one lead on each terminal if no continuity the element must be replaced. (If tests good need to test oven switch)</LI> <li>To replace the element do all of the above and remove the oven racks, unscrew the bracket that holds the element in place at the back inside of the oven, pull the element out and replace with the new one.</LI></OL> <p> <br> <p><b>However, do not remove the element until you have the replacement as reenergizing the unit with wires unplugged can cause electrical arching (direct short). </B><br> <p> <br> <p><span> </SPAN>Thank you for choosing FixYa.com<br> <p> <br><span>Justin </SPAN>
on Mar 28, 2011 • Ovens
tip
How to Replace an Electric Oven Element
Replacing an oven element is quite simple that almost anyone can do it.
  1. First pull the oven away from the wall and unplug it.
  2. Next, remove the rear panel from the oven.
  3. Now disconnect the element from the wires that power it, they should pull straight off of the element.
  4. Remove any screws that might be holding the element in place, check both in the oven and on the back. It depends on the make and model where the screws may be.
  5. Last, remove the element by pulling it out through the heating chamber, and replace with the new element. Simple as that.
For replacement parts, check repairclinic.com which I recommend, otherwise local stores may have what you need or the manufacturer themselves.
Congrats, you have just learned how to replace an element.
How do you remove the bake element from the oven to replace? Thanks
Hello- Most elements are fairly easy to replace. Unplug power.  Remove back panel and locate wires that plug into element. Unplug and remove screws holding element in place. Replace element, hook up wires, and put back panel on. Plug in and you should be good to go.  Please acknowledge post if info helps- have more if needed-- Thanks- Ed
I need to replace the bottom element in my oven
You need to check the heating element for continuity and the thermistor for continuity. Use an ohmmeter or multimeter to check. The element should not be any reading over 24 ohms for a 220-250V supply and not over 12 ohms for a 110Vac supply. A good tip is to take digital photos of the job before starting on removing and testing wiring etc so that you can refer back to it if you have to replace any items or forget which wires attach to any particular terminal etc.
To test and replace the element:
  1. Turning off the mains power to the oven.
  2. Remove the lower back panel. Fan assisted ovens will have a coiled 2 or 3 turn element around the outside of the fan.
  3. Remove the 2 power connectors to the grill element if one is fitted.
  4. Check the element resistance reading on the main oven heating element and not the grill element.
  5. The thermistor or fusible link is located on top of the oven cavity if fitted and has two wires attached to it - most likely to be red and black or both white wires.
  6. Remove the earthing wire to the main oven heating element screw terminal.
  7. Unscrew the grill element securing screws(s) - there will be 1 or 2 depending on the element fitted to your oven. Do this from inside the oven cavity itself.
  8. Refit the new element (make sure it has the same mounting screw holes as the one you want to remove) then secure it.
  9. Reconnect the earthing wire to the element screw post.
  10. Make sure that neither of the element tags touch the chassis - check with a continuity tester of ohm meter and adjust if required.
  11. Reconnect the power cables to the main oven heating element.
  12. Reconnect the power cables to the grill element if one is fitted.
  13. Reconnect the power and check that the element works correctly.
  14. Disconnect the mains power again and replace the rear panel(s).
  15. Reconnect the mains power and recheck that the oven, and if appropriate the grill, functions correctly.
Nov 14, 2009 • Ovens
5helpful
2answers
It would appear that the main oven element is not working. I had a power cut whilst using the oven recently and have only just realised that the oven will not heat up. Everything else is working ok. If it...
If it is a fan forced oven, the element is round in shape and goes around the fan blade on the back wall of oven.
To replace: Turn off power!!
-Remove side racks from oven, then remove rear panel.
-You should now see fan blade and fan element.
-You need to remove oven from cavity, then remove rear outer panel.
-You can now access element- it will be held in place by 2 small nuts either side of element wiring connections. Disconnect element wires, unscrew nuts. Element is now removed!
Reverse procedure to reassemble and test. If oven is heating OK, also check main oven thermostat is regulating temperature (ie clicks on and off), as sometimes thermostat can fail if element has blown
Aug 10, 2009 • Smeg Ovens
5helpful
Main fan oven does not work, conventional main oven does work
The element is where you said and yes it can be replaced without removing the oven. Remove the bacplate from inside the oven and you will see the element and fan. Remove the screws from the element and gently pull it forward then remove the 2 wires and keep hold whilst you fit the new element. Replace screws in the element refit the backplate job done.
3helpful
Hotpoint EG900X rear round heating element
If the fan is working, but there is no heat from rear element, then the element needs replacing.
Remove inner rear cover of oven, you will see the element there, remove, and replace.
Please leave a rating for my suggested solution.
Thanks.
1helpful
Replace Bottom Element in Belling XOU270
If this is a fan assisted oven, then there is no bottom element, only the fan element..
Remove the panel at the rear of the oven, there you will see the element, remove any screws that you can see and pull element towards you, disconnect the leads, don't loose them, and replace element.
If no screwws are visible then you will have to remove the oven from housing and do it all from the rear of the oven. Make sure power is off before you do anything.
Good luck.
Plz rate my solution.
Thanks.
3helpful
How to replace a fan bake oven hidden element
Before attempting any repairs, make sure the power is turned off! If you are unsure or not confident, please call a service technician.
The element is behind a cover that is held in place either by screws or clips. Once the cover is removed, the element will be visible. The element will be screwed in place by a number of screws on the base plate and around the element itself. After removing the screws, pull the element fron the rear of the oven. the wires should be attached to the element via lugs. The lugs need to be unattached from the element. Before removing the wiring, take note of the connections so that reinstallation can be carried out.
Top DeLonghi Ovens Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a DeLonghi Oven Expert? Answer questions, earn points and help others
