You have a valve problem they are getting superheated and unseating them selfs when there hot and makes it hard syarting need valve job done
Sounds like its a fuel starvation problem, an engine will generally run fo approx 10 mins with a bowl full of fuel before stopping. check that the fuel is running out of the pipe at a good steady rate. if not the fuel tank,pipe or filter could be blocked. if fuel is flowing ok then the carb will probably need removing and cleaning, but you may get away with just removing the carb bowl and cleaning it out
Change the spark plug
if no better suspect the coil
Check the fuel cap vent is not blocked this will draw a vacuum in the fuel tank and prevent the fuel flowing after a short time.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
