It turn green yellow then red then blinks red
SOURCE: ps3 won't power up!!
the Yellow Light of Death has hit your console. you must have the unit repaired...or replace it.
SOURCE: light turns on, light turns yellow, light turns red and blinks.
Your ps3 has overheated. This is the equivilent to the red ring of death for xbox 360. The ps3 problem is called "yellow light of death" this means your ps3 has died due to the console being overheated. The solution to this problem is either getting a new playstation or take it to a shop in the UK and they could help you fix it for a price around £30-£50 GBP.
SOURCE: ps3 power light turns green then yellow then
Your Playstation 3 has overheated. You will need to take it to a shop and in the UK it can be fixed for a price of around £35-£50 GBP. You wont need a new one, take it and they can sort out the problem. If you have warranty you can get it fixed for free. Hope this helps.
SOURCE: when i turned on my
Hello there damian If you have the brief
flashing yellow light, then its followed by a red blinking light then
you have the yellow light of death AKA the YLOD. The lights are a
warning sign to let you know something is wrong. I can give you the
quick explanation, There are 2 chips on the motherboard inside the
PS3, the GPU (graphics) and the CPU (brain), when playing the ps3 the
solder heats up and when you finish playing it cools down, over time
this will cause the soldering to crack and the chips to lose
connection with the motherboard and you get the YLOD. WHERE TO GO FROM
HERE Option
1 - Call Sony In warranty the Price
is Free, out of warranty the Price is $150,
the whole process is 4-6 weeks You can call Sony and
they will collect the PS3, repair/replace, and deliver the PS3 back
to you Option
2 - Fix it your Self You can use a PS3 fix
manual to get this fixed easily and at home using household tools you
probably already own. Click
here to know more on PS3 Fix Manuals which has helped so many
people like you. Good luck Best regards Peter
SOURCE: my ps3 when i go
Hello there sfmsoberspir If you have the brief
HERE Option
to you Option
