Samsung SGH-i900 Omnia Unlocked Cellular Phone Logo
Posted on Jul 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot enter my password on the screen when i click on unlock nothing happens even thou the password has been key in
J. Bradshaw
Level 2:
Sniper:
  • Expert 121 Answers
  • Posted on Jul 10, 2009
J. Bradshaw
Expert
Level 2:
Sniper:
Answers
121
Questions
Helped
87652
Points
323
Contact service provider. They will walk you thru on what to do.
2answers
Supervisor master password Acer 5250
How to Reset your Acer laptop, when the Acer logo shows up on the Laptop computers screen press Alt + F10 to get into the recovery partition. If it is not able to restore to factory settings completely, you might need to restart Acer laptop, and press the F2 key to get into BIOS setting, and then go to Boot menu to set D2D Recovery as Enabled. 2.
Did a fresh install of Windows XP with new media disk, but after the installation, I can't get past the admin password and log in
Restart the computer. Repeatedly press the F8 key until the Advanced Boot Options screen appears. Select the Safe Mode option using the up and down arrow keys
then press the ENTER key. Choose "Windows XP Home/Professional" depending on the version of the operating system. Press ENTER. Shortly, the welcome screen should show.
Log in as "Administrator"
Click Yes to not use System Restore Mode.
Click the Start button. Choose Run and type in "control userpasswords" (without the quotes). Click OK
Select the "Administrator" user.
Click Change my password. Enter a new password in the corresponding text boxes.
Click OK. Write this password down and store it in a secure place. I do not recommend that a password hint be used.
Close the User Accounts window and restart Windows.
hope this helps
How do i unlock a dell laptop
if you are using xp
Restart your computer during the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system.
Log in as "Administrator". Click Yes to not use System Restore Mode.
Click the Start button. Choose Run and type in "control user passwords" (without the quotes). Click OK.
Select the "Administrator" user. Click Change my password. Enter a new password in the corresponding text boxes. Click OK. Write this password down and store it in a secure place Close the User Accounts window and restart Windows.
hope this helps you
How to unlock my password?
Resetting password (username and password): b> *Start your computer
*Keep pressing "F8" as the computer starts.
*This will enter the computer in Safe Mode.
*(When the window "Advanced Boot Options" opens, choose "SafeMode" with arrow key and confirm by pressing the Enter key, then computerenters Safe Mode.
*Once you are in the Safe mode Click "Administrator" on the Windowslogin screen.
*Take note that you have set the Administrator password before, you need toinput the changed password instead of leaving "Password" field blank.
*Then click Start > Control Panel > User Accounts > Select the accountthat is locked and change the password.
**Restart computer and login into the account you just created using your newpassword.
I forgot my memory card password .. plz help ??? thnx
you can use the Nokia 5310 for many different storage and entertainment functions. The mobile phone has the ability to save all of your large files (such as pictures) to a memory card instead of using up all of the built-in device storage. You may run into issues with the memory card if it is locked. This can happen if you buy a used card or if you forget the password that you programmed into the card at the time of purchase. You can unlock the card with a default password, or you can delete the option that requires the memory card from requiring a password at all.
Instructions
          Unlock the Memory Card
    1. Power off the Nokia 5310. Put the memory card into the memory card slot on the Nokia and then power on the device.
    2. Click the "Menu" key down from the main screen of the 5310. Select the menu option for "Extras."
    3. Navigate the cursor down to the bottom of the page. Press down on the option for "Memory Card."
    4. Click the "Options" selection that appears as a screen prompt. Move through the options until you reach the "Unlock Memory Card" option. Click the cursor to select the "OK" option.
    5. Manually enter in the unlock password with the 5310 keyboard in the password box. When you cannot remember the password, the generic passcode is "12345" or "1357."
          Delete the Memory Card Password
    1. Power off the Nokia 5310. Put the memory card into the memory card slot on the Nokia and then power on the device.Click the "Menu" button down from the main screen of the 5310. Select the menu option for "Fun & Apps."
    2. Scroll down to the selection for "Gallery" and then press on the "OK" key. Navigate to the "Memory Card" screen selection and then press on "Options." Move through the list until you reach "Memory Card."
    3. Press down on the option for "Delete Password" when the screen pop-up menu loads. Verify that the words "Memory card will unlock now, do you wish to proceed?" appears. Select the option for "Yes" to verify the unlocking.
    4. Navigate to the password box and manually type in the default passcode. When you cannot remember the password, the generic passcode is "12345" or "1357." Select the "OK" key when you are complete to remove any passcode requirements from the 5310.
SIR, I AM USING NOKIA 1600 MY PHONE KEYPAD
Try following steps to get your cell unlocked with out even putting password after you unlock it reser your phone:
  1. Press Right Selection Key to enter unlock screen where you are asked to put pass code.
  2. Press Left Selection Key to go back to stand by screen.
  3. Again Press and hold Right Selection key till you are prompted [Now press *].
  4. Press [*] immediately as you are prompted while releasing Right Selection Key.
Your cell is unlocked.
Locked up HP Ipaq Pocket PC
find your manual and use the default password since the unit had been reset.
HELP!! PLEAse!!!!!
What you have done is put a BIOS password on your system, all you have to do is enter the password you typed after you hit F10 the first time when the system boots up. if the password does not work try hitting the caps lock key and entering the password again.
4helpful
3answers
Passwords
Go to http://wii.marcansoft.com/parental.psp and enter your 8 digit confirmation number there. When you do so, make sure that whatever today's date is, your Wii is set to that date. (And select Today's date from one of the 3 possible choices.)
(To get the confirmation number, go into Parental control settings, click I forgot on enter pin screen, and Click I forgot on answer secret question screen. This is where you come to where you enter the master password, and the confirmation number you need, to get this master password.)
(BTW, the number to ring up Nintendo, if you wish to go that route instead, is 1-800-255-3700, however, the website route posted, will get you your unlock code much faster.)
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
