The in use alarm appears to be related to fax reception and printing. There are some options below that you could try:- Memory Reception If the machine receives a fax under one of the following conditions, it will not be able to print the received fax and will store it in its memory. The In Use/Memory lamp is lit and Received in memory is displayed on the LCD. When the problem is resolved as described, the fax stored in memory is printed automatically.
Ink has run out: Replace the FINE Cartridge.
Routine Maintenance Note
You can set the machine to forcibly print a received fax even if the ink has run out.
However, part or all of the fax may not be printed since the ink has run out.
Also, the contents of the fax will not be stored in memory.
If the ink has already run out, we recommend that OFF be selected for Auto print in FAX user settings to store the received fax in memory and print the fax manually after replacing the FINE Cartridge. After you replace the FINE Cartridge and select ON for Auto print, the fax stored in memory will be printed automatically.
Paper has run out: Load the paper and press the OK button.
A different size of paper from that specified by Page size is loaded:
Load the same size of paper as that specified by Page size, then press the OK button.
Page size is set to other than A4, 8.5"x11"(LTR), or Legal (or 8.5"x14"):
Set Page size to A4, 8.5"x11"(LTR), or Legal (or 8.5"x14").
Media type is set to other than Plain paper:
Set Media type to Plain paper.
You pressed the Stop button to cancel printing of a fax: Press the FAX button
Alternatively turn the printer off, open the devices and printers section of Control Panel, right click on your printer and select "see what's printing" and left click on this. A window will pop up which may or may not contain a list of documents. If it does these must be cancelled (Menu - Printer - Cancel all documents). Once all documents have gone from the list turn the printer on and try to print.
Other than the above suggestions I would need to know more about your OS and exact problem. Hope this helps.
Issue:
ERROR LCD: WAITING FOR REPORT Solution:
Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX
When
[AUTO PRINT RX] is set to [OFF], incoming received faxes will be
temporarily stored to memory and transaction reports (TX, RX and
Activity) remain in memory. The default setting is [ON], which means
incoming received faxes and transaction reports will automatically
print.
The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
Ink is low or has run out
The paper size and type is not set correctly
Paper has run out
The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
Press the <FAX> button to enter the Fax menu.
Press the <Menu> button. [FAX SETTINGS] is displayed
Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
Press the left arrow to select [ON], then press <OK>.
Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
CAUTION:
When this option is set ON, the fax machine will not monitor the ink
level of the ink cartridges. If ink is low or out, received faxes will
print with streaks or blank. Furthermore, once the fax is printed, it
will be deleted from memory.
To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
To
store received faxes in memory when ink is low or out, press the left
or right arrow to select [OFF] and then press <OK>.
Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Description of Problem 100000018247
When I launch PC-Fax Receive Program, I receive an error stating: The Fax Receive program must be started to receive PC faxes. What can I do?pc fax rx
Description of Solution 200000023257
You may receive this error if the pc fax application is closed and you have faxes stored in the memory of the machine. To resolve this issue,you will need to print the faxes already stored in the memory of the machine. To print the faxes, please follow these steps:
1. Press the MENU key.
2. Press the UP OR DOWN ARROW key to select Fax.
3. Press the OK key to confirm your choice.
4. Press the UP OR DOWN ARROW key to select Print Fax.
5. Press OK.
6. Press the BLACK START key.
- Your Brother machine will print the stored faxes.
7. Press the STOP/EXIT key to exit the menu.
8. Once the stored faxes have been printed, click WINDOWS/START, (ALL) PROGRAMS, BROTHER, XXX-XXXX (X = MODEL NUMBER), PC-FAX RECEIVING, XXX-XXXX or RECEIVE (depending on your operating system).
9. The Brother PC-fax receiving icon will now appear in your Windows Task Tray indicating that Brother PC-Fax Receiving is active.
receiving incoming fax in the memory, displaying "memory received" but never print out. I wonder if there is a way to retrieve fax from memory and print out manually?
RECEIVED IN MEMORY
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will store it in its memory.
Ink is low or has run out while receiving a fax: replace the FINE Cartridge.
Paper size/type setting is incorrect: correct the paper size/type setting.
Paper has run out while receiving a fax: load the paper and press the OK button.
Output Tray is closed: open it. OFF is selected for AUTO PRINT RX: select ON.
You pressed the Stop/Reset button to cancel printing of a fax: press the FAX button.
Dear guys, your toner cartridge is low and as a preventive measure, the unit stores the faxes in order to give priority to copying and printing. If you are using remanufactured cartridges, the unit might not be displaying the low toner warning.
TYPICALLY A FAX MACHINE WILL RECEIVE MESSAGE IN MEMORY WHEN NO PAPER OR TONER/INK FINISHED INDICATION IS THERE, REPLENISH THESE SUPPLIES WITH GENUINE ONES AND FAX WILL START PRINTING.
IF PROBLEM IS NOT SOLVED , PLEASE TRY TO CLEAR THE SETTING FOR MEMORY RECEIVING,
IF STILL NOT SOLVED TRY BRINGING THE MACHINBE TO FACTROY SET SETTING BY CLEARING THE MEMORY.
HAPPY FAXING
OMNIPRESENT
