A
Anonymous Posted on Mar 14, 2015
Minolta EL 1054 giving drum sign how can I reset please give me the simulation
Norman Weimar
Level 3:
  • Minolta Master 7,035 Answers
  • Posted on May 10, 2015
Norman Weimar
Minolta Master
Level 3:
Answers
7035
Questions
Helped
1910664
Points
11959
First replace the drum, then clear the counter, machine works off the counter, clearing the counter without a new drum will have the machine set voltages to certain assembly according to what a new drums needs when in fact it is old causing image problems. to reset go to service mode stop 0 stop 01
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2 Related Answers
Cogz
Chris Coughlin
  • 1326 Answers
  • Posted on Feb 27, 2009
SOURCE: in minolta 1054 there is a sign like box and
Have you adde toner resently??? It is one or two things either add toner or empty out the waste toner...
Cogz
Chris Coughlin
  • 1326 Answers
  • Posted on Apr 25, 2010
SOURCE: I want minolta ep 1054 simulation code,please help
I think you are looking to get to service mode. The switch is on the back of the copier > you will have to take the back pannel off. The dervice switch looks like a small Black botton > it is on the main control PCB.... press it once and make sure the doors are closed and then go to the reset mode and you are good to go.
How to clear c03ff in Minolta cspro 1054
sir as I said before
Replace the drum and developer and run the required F codes
How to clear c033ff in Minolta cspro 1054
as i said before sir
How do i solve my minolta copier cspro ep 1054 printing blank document
check the transfer wire assy. located under the drum. might not have a good connection or the High Voltage unit is bad. That is a very old machine.
.EP 1054 does print faint on the page even darkened
Please open the back cover ,see the motherboard it has a reset button press it than machine are reset (Please press the reset button when machine power on)
I want to reset minolta 1054
please open the back cover press the motherboard rest button.
Reset drum minolta di 2510
Has the drum been replaced? IF not then recommend that the counter not be reset because the copier use the counters to determine voltages for certain assy. like drum and developer unit, so if you reset the counters with out replacing the parts the machine will give codes and provide bad copy quality issues. Reset code is the only way the machine knows it got new parts
2helpful
Minolta EP 1054 - need to change the cleaning blade
Hi, I have all spare Minolta EP 1054 copie.But quistion Where you live? If you live in Bangladesh.I will give you.But if you live another country you send money I send it by DHL.Please contact us [email protected] or call 08801819879575.
8helpful
2answers
I want minolta ep 1054 simulation code,please help me
Reset drum
Hello sir; after you replaced drum there have 4 simulation you have to do;
1, simulation26-7 to match the first digit of the four digit printedon drum.
2, simulation 24-7 drum film wear correction counter reset.
3, simulation 44-6 patch forming voltage.
4, simulation 44-2 drum mark senser level standard value is 90.
To get in simulation the procedure as follow;
1, press "clear", 'pause", "0", "pause". then enter the simulation number one by one. GOOD LUCK !!!
In minolta 1054 there is a sign like box and asmall arraw becid i want fix the broblem if u please
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
