SOURCE: Walking during the spin cycle
Is your floor level, first thing. Okay, the rear 2 legs are not adjustable so leave it. The front 2 legs should be screwed up (ie the machine should be at the lowest level in front) and there are check nuts to tighten inside the body of the machine. Check the machine it it rocks by using your hand against it. Adjust accordingly, this is if your floor is not too good. You shd not hv any problem. If the rocking persists check inside machine, behind after getting he plug off wall, maybe shockabsorbers hv come off, springs?.....
and rate me please if helped.............
SOURCE: Maytag Neptune out of balance on spin cycle
Hi, try to check the spring virator support might pollout from slot or hole connected, some adpter are rusted spring replace it are also available in appliances store.
SOURCE: balancing
This type of thing should not be required. Front load washing machines (well, topload too i guess) will balance themselves out for the spin cycle unless the machine is grossly overloaded.
Good luck.
SOURCE: washer vibrating badly
Try these
pls rate my suggestion......
