Can't figure out how to set the time or date on my sons new watch! Instruction manual wasn't in box and the watch has only two buttons on right side. Top button activates LED light up effects and the 2nd button cycles a 60 second timer, date(which is incorrect) and the 3rd press brings you back to the digital time( which is incorrect also)! The model number is SWRKD054E15 Battery is 392 Please help! It is driving me and my 11 year old crazy lol! Jason Markovich-Ohio
Hi,I had the same problem. Look on the side of the watch on the right, in between the two pressable buttons. There is a small black button, size of a Byro tip. Press that in for 5 secs then the date display will start to flash. Set with the lower big button then press the small button again to cycle through month, day, hour, minute.
Phew. Takes a bit of spotting.
SOURCE: GapKids Digital Watch - Need to know how to set
Light button is A
Mode button is B
Start button is C
Reset button is D
Standard Time Adjustment:
1) To set time, date, etc. press button B three times (assuming you start in standard time display mode)
2) Press button D until the area you'd like to change is flashing. (i.e.: minutes, date, day, etc.)
3) Press button C to change. Press once for one unit increment of change. Hold for 3 seconds for speedy advance.
4) Press D again until the next area you'd like to change is flashing.
5) At completion of changes press Button B to resume standard time display mode.
SOURCE: Can't reset the time on digital watch
I found the solution at http://www.watchliquidators.com/fossildir/Nike.asp
Hold down the button at the top left (the light) for about 4 seconds. The second part of the time will start blinking. I tried this before, I'm sure, but I must not have noticed the blinking and thought nothing was happening.
Once the seconds numbers are blinking, push the top right button (Start/Stop) to move to the hour or minute. Push the bottom right button (Lap/Reset) to change the time. When you're done, push the top left button (Light) again.
SOURCE: Watch setting instructions
i had the same problem, follow this link it should help you
http://www.fossil.com/wcsstore/Fossil/images/en_US/customercare/digital_WorldTimeModule_Digital.pdf
SOURCE: Problem with the time setting
The only info which continually flashes is a dart and the letters chg
SOURCE: setting time/date on old Seiko
Good News you can find Seiko Digital Watches Instruction manuals from http://SeikoDigitalWatches.com its very good site about Seiko Watches.
Thanks
Kashif
http://VintageDigitalWatches.com
