There are 3 1/3 cups of all-purpose flour in a pound.
There isn't an accurate way to do this. If you take a pound of flour and measure it, then sift and measure it, the difference will be significant. The sifted flour will take up a greater volume making it seem like there is more (by volume). In short, don't try to convert weight to volume (directly).
Http://calculator-converter.com/converter_c_to_lb_cups_to_pounds_calculator.php
Here is how you determine the size of loaf you can bake in your machine. You need to determine the capacity of your pan. Fill your pan with water and measure the cups added so you know how many cups of water are in the pan when it is full to the very top. Here are the conversions:
1)If your pan holds less than 10 cups of water you can make: a 1 pound loaf
2)If your pan holds 10 cups of water you can make: a 1 pound loaf and a 1.5 pound loaf
3)If your pan holds 12 cups you can make: a 1 pound, 1.5 pound, and a 2.0 pound loaf
____________________________________________________________________
This is rare, but if you pan holds 14 cups or more you can make all the above plus a 2.5 pound loaf
FROM ANOTHER SITE:
To find your bread machine pan size:
Fill the bread pan with water and measure it out in cups
Less than 10 cups of water = 1 pound
11-13 cups of water = 1 1/2 pounds
More than 13 cups of water = 2 pounds
You don't need the bread pan cover unless you are making butter. If you are making bread you should always leave it off or it could melt from the heat of the baking cycle. The butter cycle doesn't use heat. Please rate this answer with testimonial/vote/rating etc Thanks!
FROM ANOTHER SITE:
FROM ANOTHER SITE:
FROM ANOTHER SITE:
