965 76 02 06 is the product number, 2400291 is part of the ser no. however it is too short, ser no.s are 9 digits, after the year 2000 the first two digits will be the year, e.g 00 is 2000, 01 is 2001, 02 is 2002, and so on, the next two digits will be the week within that year, e.g. 03 2400291, is 2003 week 24.
The 2000 model year Accent adopts a different "pressurized" leak check system capable of detecting a 0.020" (0.5 mm) diameter leak (previous Hyundai systems detect a 0.040" [1mm] diameter leak using engine vacuum). The new system uses a Diagnostic Module for Tank Leakage (DM-TL) to close and pressurize the fuel evaporative emissions system. The DM-TL replaces the fuel tank pressure sensor and the canister close valve from previous systems. Other significant changes were made to the system logic, including several new diagnostic trouble codes. It compares the differences between the 2000 model year Accent and previous evaporative emission systems...
Que puede ser? Tiene dos opciones. Primero, puede pagar que un tecnico diaga el problema (exactamente) o sigue, secudariamente, su adivnaza.
mfg date are coded into the ser.# useualy fist 4 digits are yr and month of MFG. 0306 would be 2003 june ect. if in doubt call amanna dealer and ask them. Steve
