Hayward H250FDN Low NOx Natural Gas Pool or Spa Heater Logo
Posted on Jul 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Heater is new, installed at grade on above ground pool that is 48" deep so pressure switch is 3' below the water line. With pressure switch adjustment turned fully clockwise the heater will run without the pump on. Pressure at switch is approx 1.5 PSI. Is the switch faulty?
John Prohaska
Level 3:
President:
  • Hayward Master 1,378 Answers
  • Posted on Jul 10, 2009
John Prohaska
Hayward Master
Level 3:
President:
Answers
1378
Questions
Helped
688661
Points
3511
Adjust the switch fully in the opposite direction. If you are at 1.5 you are at the light end of the adjustment range of that switch, which can be adjusted up to 5psi. Then let it back off until it works reliably. Rarely do you need to adjust a pressure switch on an above ground pool so it should end up about in the middle of the adjustment scale.
How to adjust pressure switch
unless heater is below water level or above water level switch should be ok syphon loop might be clogged
How do I adjust the pressure switch on my hayward h250 heater
The purpose of the pressure switch is to verify the pool pump is operating properly and water pressure is present in the heating chamber. When water pressure is not present, the heater control system is designed to not allow initiation of flame. The pressure switch is preset at the factory for deck level installations. When the heater is located below the level of the spa or pool, the pressure switch may require an adjustment to compensate for the no-flow static head.
CAUTION: The Hayward Pool Heater is essentially a furnace. A trained technician should be consulted to repair it. DO NOT OPERATE the Hayward Pool Heater without a properly functioning and calibrated water pressure switch. The pressure switch adjustment requires both the pool pump and the heater be operational. As a result, extreme caution should be used during this procedure since sources of energy can not be isolated during the procedure.
The following procedure is recommended to calibrate the pressure switch.
1. The water pressure switch is located behind the front service panel. The pressure switch is typically on the left side, above the burners.
2. Be sure the water filter is clean before making the adjustment.
3. With the pump and heater system switch on, carefully turn the pressure switch adjustment dial clockwise, until a click is heard from the gas valve.
4. Turn the adjustment dial counterclockwise 1/4 turn.
5. Turn the pump off and on several times. The heater should shut off immediately when the pump is shut off. If the heater fails to shut down when the pump is off, repeat the steps above until the pressure switch is properly adjusted.
6. If the adjustment process fails to produce proper results the pressure switch should be replaced.
Hello I have i 18 foot by for foot deep above ground pool with the blow up ring. It is about 3 inches lower on one side. Well we got in it today with no problems of water coming over the ring. Well ...
above ground pools have to be erected on perfectly level ground. If you have one side 3 inches lower than the other then all the weight of the water is against that lower side and eventually the water will overcome the air pressure in the ring and it will collapse and let the water out especially if the ring has a small air leak and looses pressure. You are lucky that you do not have a pool with 4ft sides as the loosing water effect is remarkable and will wash away any thing in it's way. Use the water in the pool as a level and adjust the base ground so that the pool sits level all the way around.
Installed new 250 unit today, getting error code IF, Gas is on, gas valve in front panel is open, unit grounded, gas feed line necked down to 3/4 npt at shut-off valve, tried to increase gas pressure 1...
Did you bleed the gas line of air? In a nw installation it is not uncommon to sit there 20-30 seconds with the gas line union open and the shutoff open to get all the air out and a good flow of gas present. If that doesn't work post a comment with what else happens.
John
Rapak above ground pool heater is leaking from the bottom
leak is prolly from pressure switch connection or heat exchanger...... if from heat exchanger buy a new heater
How do i install my raypak pool heater Model
Yours is an in ground pool, right???
Break the return line between the filter output and the pool. That is where your heater goes. If you have a chlorinator ... it should be between the heater output and the pool (chlorine is the last thing to go into the water before the pool). You will need a fuel line of appropriate size for the heater and either 110 or 220 volts of power. Your heater shold have a safety built in that prevents its operation unless there is water pressure.
Pool pump shutting off/tripping the circuit breaker
What kind of pump are you using?
Sounds like the Intex is restricting water flow there by heating up your pump and shutting it down..
You may need to re plumb everything to handle the flow.
Intex hoses and fittings are different than the industry standards just so the can make you buy from them
Do what ever it takes to get good flow
How deep can we dig for oval deep-end pool
This blog has information about sinking an above ground pool. It is normally recommended that you do not sink the pool entirely into the ground becuase of pressure concerns and the risk of collapse. Generally, you leave 1-3 feet of the pool above the ground and install a deck or similar feature to make the pool appear to be in the ground. The type of pool liner that you have (expandable) is best for this practice, but it can be done with overlap or regular beaded liners also.
http://backyardcity.wordpress.com/2009/06/02/the-above-ground-pool-goes-underground/
Need flow rate and pressure adjustment proceedure for an old raypack 266 not electronic.thanks murray
The maximum flow rate for that heater to be installed in without a bypass is 125 GPM. The owner's manual can guide you thru gas pressure adjustments or adjusting the set point of the water pressure switch. Please note that unless you are installing the unit below or significantly above the water line you should not have to adjust the pressure switch. Whenever you do adjust it, be certain to turn the pump on and off several times to be certain the heater reacts to the pump condition...failure to shut down when the pump does can be a serious and dangerous condition.
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
john h
ZJ Limited
ZJ Limited
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
