If it's an android, you can change it within an app - like camera. Go into settings and change default storage location from internal storage to sd card.
If the app can't see your sd card, make sure it's "mounted" within your device. Depending on the software version: Go to settings, general, phone/tablet management, storage, from here you should be able to see the sd card. It is either ejected or mounted. Click on the sd card, if you can see the folders content, then it is installed correctly.
Also, if it was used in another device, it may need to be formatted to be used in your tablet. You can do that from the same setting menu.
Most apps only use the SD card to store their data. The actual install is on the phone/tablet memory. If you are changing phones, there are many backup programs that allow you to back up selected apps to your desktop PC and restore to your new phone. I believe some may backup the app to your SD card also, however the PC backup is easier for me.
not all apps can be transferred to sd card. some built in apps are not transferable to sd card. If sd card has no light then that apps cannot be transferred to sd card.
In your settings you can find 'applicaton manager' find the app in question and press it. There should be a 'move to sd card' button. That should transfere most of the app data to the card for less tablet memory usage.
Hi if you want transfer your apps on sd card go to setting- application manager- choose the app and there you will see a move to SD card button, just press it and after a while your app gona be transferred to memory card. You need do it for every app sepretlly. If you want store a photo's on it go to camera- setting and there press storage and choose memory card. With music create a folder music on it using my files and player should detect it automaticlly if not navigate there.
Hi Insert the SD card into the SD card slot on side of Tablet the correct way round. Taking note of the angled side of the card in relation to the diagram on the Tablet case. Start Tablet, go to settings, storage, scroll down to SD card & mount the card. Once the card is mounted it's ready to use. Remember to unmount the card before removal to reduce the risk of data loss. Hope this helps. Regards Bob
If connecting the Tab to the computer with the cable and then correctly mounting the SD Card through Android (tap notification, follow steps) does not work, try a third-party app like On Air to connect over-the-air.
Hope this helps,
Alistair
