Garden Logo
A
Anonymous Posted on Mar 09, 2015
Ryobi 9600 backpack blower. Starts great. Set to run, continues running. Upon attempt to use throttle, engine dies. Acts like choking out but removed carb cover an choke is no closing.
Ryobi 9600 backpack blower (3rd or 4th season). Starts great. (Choke working properly). Set to run, idle automatically increases. Upon attempt to use throttle, engine dies. Sounds like it is choking out, but after removal of carb cover, th choke is not closing at this time.
J.D. Browning
Level 3:
  • Ryobi Master 2,760 Answers
  • Posted on Mar 12, 2015
J.D. Browning
Ryobi Master
Level 3:
Answers
2760
Questions
0
Helped
1013814
Points
6696
This sounds strangely like the high speed jet/pathway in the carb is clogged up with something ,
the best way to fix it is dissasmbly and cleaning of carb in solvent , but ive also had some limited sucess in past of using car fuel cleaner (says on bottle "cleans as you drive") too
1helpful
I have a Ryobi S430 4 stroke Weed Eater Trimmer. How many times do i pump the choke (primer) to start cold?
chokes are an obstruction placed over the inlet to increase the vacuum in the carby and cannot be pressed
Primer bulbs are used to suck fuel through the diaphragms to expell all of the air in the system to allow starting
normally press the primer bulb until it is full of fuel
apply the choke and pull until it fires
remove the choke and at full throttle pull until it starts
Ryobi ry08576
make sure your fuel is fresh and mix at 50:1
then remove the muffler and try to start it holding the throttle wide open... if it starts and runs fair suspect a flooded engine, plugged muffler
if not, suspect a carb adjustment issue and then a carb
I hvae a Backpacker blower that starts easily and idles great while choked, but will not run on high throttle whether choked or not
Soafter you get it started, the blower wont run after choke is disengauged. If you give it gas to blow it cuts off...rite?? Have you adjusted the idle mixture screws? if so and it dont work, have you checked spark plug ? Need to know more for better diagnosis.
Aug 18, 2011 • Garden
Blower will only run on full choke ryobi ry08578
They aren't designed to run with full choke on, the choke is for starting cold engines only, many times you can choke them pull the cord a few times and then turn the choke off or turn it down to start it. Then slowly reduce the choke until it runs fine on its own.
Engine starts easy. Engine can only achieve high
eitrher a clogged fuel filter thats in the tank, old gasoline or the fuel pump daiphragm in the carb has hardened
2answers
Low RPM's Ryobi 25.4 cc backpack blower
Remove the muffler and you should find that it will run at full speed. The muffler is clogged with carbon. You will have to replace the muffler since it is sealed. If you want the muffler cleaned you can contact southern supply company at 205-833-2525 or email them at
[email protected] and I feel sure Jason or
someone there can help you.
1helpful
2answers
It acts like it is flooded, starts with choke off and throttle depressed. runs until carb runs out of gas then dies
Yes, Your carburetor sounds like it needs cleaned. Or you may possibly need to purchase a carb. kit for your trimmer if the cleaning doesn't do any good. When cleaning the carb. use a Den Tek Brush, (teeth cleaning brush), to clean the small ports. Also, check the small screen in carb. Can get clogged easily.
Jim
May 28, 2009 • Garden
1helpful
Leaf blower will not achieve full RPM's
try removing the muffler and scraping out any carbon build up in the exhaust mouth of the block. if that doesnt help you will probably need to replace the carb.
Top Ryobi Garden Experts
Jay Finke
Jay Finke
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
