I can buy a PLT-3043YW (30cc) at Cash converters but there is no maznual. does it use two stroke mixture or is it a 4 stroke petrol engine
Free manual online at the internet link shown below:
https://www.manualslib.com/manual/1389229/Ryobi-Plt-3043yw.html
Ryobi PLT 3043YW Operation Manual
SOURCE: RLT30HT 30CC PETROL STRIMMER difficult to start
The plug that I have in my 720r is a Champion RDJ7Y. Can I suggest that you pull the old plug out and look to see which one you have? Also when you buy the new replacement it should already be gapped for what you need.
SOURCE: Honda 4 stroke petrol leaf blower.Petrol starvation
Further to the previous response of checking for bent fuel lines. It sounds like the breather is faulty, this is integrated in the fuel cap, as you screw it down the rubber/cork gasket makes a tight seal preventing spillage but the breather allows for neutral pressure inside the tank, with fuel being sucked out it creates a negative pressure in the tank or a vacuum causing the engine to be starved of fuel as it can't draw more fuel. Check the cap for dirt or grime and possibly give it a good rinse in benzine before trying again, otherwise try and get a replacement cap. Hope this helps.
SOURCE: RYOBI RBL-30MVA 30cc when pressing the primer bulb
The diaphragm in the carb may need to be replaced. Make sure all your fuel lines are fine. On these inexpensive blowers the fuel lines tend to get brittle and crack and fall apart.
Testimonial: "thanks, will this be a costly thing to get done? will Ryobi replace the part?"
SOURCE: I am looking for Ryobi brush cutter parts
Any local small engine service shop should have these parts in stock. Its called a 'primer bulb'.
Determine if the primer bulb is part of the carb or sperate from the carb with fuel lines connecting them. If seperate remember how the 2 lines get connected when you remove the bulb and replace with a new one. If a part of the carb...
You need to determine if the carb is a Zama or Walbro. It will have the name stamped on the carb. All Zama carbs use the same bulb. Walbro has a small and large bulb.
It would be worth while to install a new carb kit while you have the carb off and apart
SOURCE: Confused a little
A 4 stroke motor does NOT have Oil in the Fuel. There is NO fuel mixture. Just use regular gas. The only place you need oil is in the sump, and regular 20/30 motor oil will be fine.This only needs to be replaced when low on dipstick in crankcase.
Testimonial: "Getting older I realise I'm losing some ball bearings and now find difficulty in thinkng straight anymore. Thanks mate for clearing my mind again."
