How do i turn off a my sony all in one touch screen, i do not touch the screen for options, and its driving me crazy
Its a touch screen, nothing is touching yet it constantly bings, we have vacummed it out, washed it off, just cannot get it to stop the bing or pinging, would like to turn the feature off anyway, we do not use it, and the kittys tail when it touchs sends the screen to do alot of things we do not want it to do, can you tell me how to turn off the screen, it is a sony all in one desktop, thank you
Re: how do i turn off a my sony all in one touch screen,...
Press the Windows logo key + X.
Select Device Manager from the list.
Click the little arrow next to Human Interface Devices to expand the list.
Click the touch screen driver (in my case, NextWindow Voltron Touch Screen).
Right-click, and select Disable from the list.
Click Yes on the dialog box that asks if you are sure you want to disable the touch screen driver.
Restart your computer
When you want your touch screen to work again, follow the process above, EXCEPT when right-clicking the touch screen driver, select Enable See the website
1.Press the Windows logo key + X.
2.Select Device Manager from the list.
3.Click the little arrow next to Human Interface Devices to expand the list.
4.Click the touch screen driver (in my case, NextWindow Voltron Touch Screen).
5.Right-click, and select Disable from the list.
6.Click Yes on the dialog box that asks if you are sure you want to disable the touch screen driver.
7.Restart your computer
See the website
I had the same, or a very similar problem. What happened with mine, was the sensor on the upper right corner of the phone was getting blocked. It is supposed to sense when you have the phone next to your face and then it will darken the screen, Mine had plastic that was obstructing it. Hope this helps.
Ok do not worry this may mean two things crached hard drive or a corrupted hard drive all you have to do is turn it on but let the red ligth be on turn it on do not remove your finger from the button until it go's off again turn it on again keep your finger until it makes a sound but still do not remover your finger untill it makes two sounds after eachouther take your finger of fast nou a screen will apear say restore sestem untill your ps3 works again it take 1-4 trys and if nothing happens you must format it.HOPE I WAS USEFULL PLZZ RATE ME AND IF THERE IS ANYTHING ELS EMAIL ME TO [email protected] I DO PS1,2,3,DVD PLAYERS AND PC sorry for my spelling i am only 13 and i afrikaans BUT PLZZZ RATE ME..........
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
put os in cd drive and boot up to install new copy .if system says ** os found you k**w you have hd problem you can try to fix or reinstall new copy anyway.remove hd and re seat it first.check mem .remove ,check connections and replace.go into bios and select default.save and exit.
see how you get on .
sounds like missing or conflicting software but try all the above first.If it is missing or conflicting software pretty easy to fix.let me k**w
See if one of the button switches is collapsed, check the "shoulder buttons" also. If any switch is collapsed, it will sense that button as being held down all the time, and may act strangely, including ignoring commands from other inputs or controls. Its possible a bad touch screen could do something similar as well.
Check that all the switches still click and return as they should. If you disassemble unit, you can eliminate the touch screen temporarily by just unplugging the very small ribbon cable to the touch portion of the screen, then see if it still acts up.
Me too! The camera was working perfectly until yesterday and when I turned it on today, it selectively ignores some buttons on the screen - and pressing the "Menu" gives me nothing. I've tried to reset it through that pin hole button, but it just resets the machine back to its default.
