Check and clean both spray arms.
make sure nothing is restricting the movements of the arms. Have you selected the correct programme? Quick wash may not always dissolve tablets, you may need to put the tablet straight into cutlery basket at start of quick wash programme
i think there might be some programming fault . so set the timer again or
start pause button
after having selected the required programme press this button to start the machine the corressponding pilot light stop falshig. to interrupt the programme which is running depress the start/ pause button the corresponding light start to flash. to restart the programme from the point at which it was interupteed press the start/puase bitton again.
hi
the water level switch or sensor does not activate to tell the programmer that there is plenty water so that it can start to rinse ( what you doing is simply overriding the system .
Take the toe kick off of the machine. Reach in and up to the right.
There is a "manual" which covers error codes and possible remedies but
not much more. Hope your "manual" is still there.
If your washer is a Hotpoint WF430, then the quick wash programme is L.
This is a 30 minute, 30 degree wash.
Trust this is the information you are looking for.
Please rate my solution.
Thankyou.
yes a quick wash is for coloured clothes that have been worn once or twice and dont have bad stains on them.This quick wash will take between 30 and 50 mins to do a wash and is the best programme for the clothing that I have discribed ie: worn 1or2 times and no stains will save you on electric and water peter
