Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
hello any spin problems can be caused by the module control board usually sits at the back of the washer may have a load of wires coming off it hope it helps
THe same thing happend to me just now grrr......
I'm really not a technology expert or anything but, when I looked inside of the the "button" I saw a small scratch on the green and gold plate. Did you perhaps notice anything like this? I'll probably have to replace it or something........
But seriously, I hope this problem is solved soon.......
The control board went bad. Your switch went bad or you blew the fuse. All are located behind the knobs. Just remove the knobs and undue the screws up top. Make sure to unplug the system before opening it up
