Magic Bullet Nutribullet Blender Logo
G
Gillian Higgins Posted on Mar 04, 2015
Replacement Gasket Ring how do I get - Magic Bullet Nutribullet Blender
GNC Live Well Blender BL3340. I need help finding the O-ring for it please?
Question edited for clarity.
It appears to be an eBay special. you may be able to buy using the diameter. Shops that sell fasteners sell O-rings, but this is likely wider, so more a gasket.
https://www.google.com/search?q=GNC+Live+Well+Blender+BL3340+replacement+O-ring
https://www.google.com/search?q=GNC+Live+Well+Blender+BL3340+replacement+gasket
Dec 11, 2023 • Blenders
2answers
I need a replacement seal for a GNC On- The-Go Blender Model HL 2574
I found a replacement gasket that work for the GNC on the go Shaker HL-2574 if anyone need some just send me a msg yaz109 hotmail dot com
Jan 18, 2017 • Blenders
I need 0914084 Blender Sealing Ring Diameter 2 1/16"or its substitute.
Unfortunately that gasket, part number MS-0914084, has been discontinued.
Here is a link to the part online: Seal MS 0914084 for Krups Appliance eReplacement Parts
Unfortunately the gasket is obsolete, and there are no known replacements. The gasket is very perticular and i do not know of any other gaskets that have a similar shape.
-Colleen@MendingShed
Can I get a new gasket for a GNC on the go blender
Yes, you can order the replacement rubber gasket seal ring from nutri Bullet 600w or 900w which is the same size on ebay for $1.00.
Gasket melting
Awesome...
Try AMAZON FOR THESE parts...
((amazon be cool... dogs drool & cats rule)).
4X Sealing Gasket Rubber Ring Replacement Seals For Ninja Juicer Blender...
3helpful
Need a replacement gasket for the Cook power blender
Boy, I spent some time on this and - so far as finding an exact replacement on the Internet - I'm stumped.
But I'll tell you what I'd do, in your position.
I'd take the old worn (or split) gasket to Ace Hardware or True Value, and ask someone to match it up for you. Really, a gasket is a gasket. It's just a matter of the size, the thickness, and the "compressability" of the rubber (obviously, you'll want a soft rubber gasket). If you find one, you may want to buy two of them... just in case.
If this doesn't work, then get a square piece of rubber gasket material (Ace, True Value, Home Depot, etc.). You can either cut one yourself (use cups, jars, measuring spoons that are the right diameters to draw your two ring patterns), using an Exacto knife to carefully cut them out.
If you don't want to do this yourself, ask someone who's handy & who has a steady hand to do it for you. You can pay them with a freshly made smoothie.
3helpful
5answers
Oster 6700 Gasket O-ring leaks
Gasket is not the problem.
Square shaft that is pressed into the turning gear is not tight and allows leaking through the connection.
Only repair is to replace the assembly with the gear drive, blades, etc. and this will take care of the leak. The "O" ring gasket is fine and holds the liquids. However the leak is around the center of the shaft that goes through the bottom.
Regards,
Gary
Maximatic EBL-1000 Elite Cuisine 10... Problem:
Brandy,
-the gasket is a flat rubber ring
-it is used to seal the space between the glass carafe and the plastic carafe base that fits into the base unit
-so the order is glass carafe, chopper blade, gasket, plastic ring...turn this on tightly
-place the whole carafe unit onto the base unit
NOTE: it does not fit firmly...suggest that you hold it firmly before you turn the unit on
so I hope that `fix-ya` works....if not...then ask.
...as any rating than this actually lowers my rank...just the way fix-ya works
bearb
Top Magic Bullet Blenders Experts
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
john h
Are you a Magic Bullet Blender Expert? Answer questions, earn points and help others
