SOURCE: Bunn B10-B leaks
I used Foxhollowrun's solution and went to my local hardware store (Menard's). You can purchase 3/4" Hole Grommets typically found in the electrical department. The brand I purchased was Gardner Bender Model GHG-1575 3/4" Hole Grommets. Here is all that you need to do (very quick and easy):
1) Break away the brittle pieces from the original hole in the resevoir.
2) Remove the old rubber / plastic washers - I found I didn't need them. However, hang onto your metal washer that the drain screw goes through.
3) Slip the 3/4" grommet around the hole.
4) Place the original metal washer on top of the grommet.
5) Screw the drain screw back into the heater which will seal the grommet via pressure. Be sure not to over tighten it - I just snugged mine up.
6) Put everything back together, rinse several pots of water through it, check for leaks, and you should be good to go.
As Foxhollowrun indicated, you may need to tighten the drain screw a bit if you do have a leak. I lucked out - it worked the first time. I believe it cost me about $2 to fix. Also, I did not need any caulk. If you do use caulk, I was told you need to use food-grade caulk.
One last note - as Foxhollowrun indicated, the grommets are quick thick which is why I removed all of the old washers. The original metal washer is just thin enough to allow the drain screw to be reinstalled.
Thanks to Foxhollowrun for a great remedy!
SOURCE: bunn code date 145000 water leak took apart need
If you will call customer service, a seal repair kit can be sent to you which is successful 90-95 percent of the time in fixing the leak problem.
SOURCE: Bunn Coffee Filter Basket Tray Broken
If you will contact Customer Service at 800-263-2256 with the model and date code, they will be happy to help you. The tray assembling itself is not replaceable but the machine does carry a 3 year warranty.
SOURCE: hot water leaks out the bottom when filling
If you will call 800-352-2866 with the model and date code and we will be able to help you resolve your issue.
SOURCE: I have a Bunn GR10-B - date code 252602 - how do I
You can send it in with a check/money order and have the switch repaired. If you call customer service at 800-352-2866 we can provide you the address.
