I like it, thank you very much
Freewing RC airplane official site Flightline Official site Freewing model...
SOURCE: cant get 42''lcd telly to let me play ps3 threw hdmi cable
You will most likely have to contact your LG dealer to fix this. The problem is due to the HDMI input not recognising the playstation, the cure for this is a software upgrade for External Device IDentification (EDID), which can only be done by a service centre.
SOURCE: I have a 42 LG Plasma TV with a broken screen
NO....You must pay attention to all numbers on the back of the TV. Verify these with your tech or contact your LG customer support for the correct board numbers. If the screen was broken I doubt if you can repair this for less than it cost to replace. The screen for this one runs at about $650.00. Good Luck and good advice!
SOURCE: Need a code for remote control for 42
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
go to the above link and you can click on your manual.Codes are on page 125
001,012,013,020,101,106,114,123
Hope this helps!
SOURCE: Hi, my 42" LG TV
Hi, the appearance of black streaks on the screen of a Sharp LCD TV is common problem most customers will have to contend with. One of the most visible signs is the appearance of a message that reads " loss of sync". In this situation, the individual will still hear the sound coming from the LCD TV but the picture disappears especially within 10 minutes of putting on the TV. In some other cases, small horizontal lines may develop on the LCD screen especially when an object is thrown at the screen -the horizontal lines develop at the spot where the object hits the screen, and these lines are often visible when the TV is turned on and such problem is characterized by Grey color screen with no pictures.
Another common situation is the appearance of vertical red line across the LCD TV screen. In this case, the connection from the internal ribbon connector and the display has been effected. This problem may degenerate into the formation of two screens which are separated by a black line .
LG TV screen repair for Black streaks on screen
The best possible LG TV screen repair for vertical lines on your LCD screen is the replacement of the screen itself. It would be ideal for you to know the warranty status of your LCD TV before returning it to the manufacturer. In the case of the formation of black streaks on the LCD screen, a possible reason is that one of the substrates in the screen has been fractured or it can be a result of the release of some bubbles within the screen, especially after the screen was hit by an object. You don't have to think much about this problem, as it should be in your best interest to get a LCD TV repair service to replace the screen for you.
In some other cases, some other components of your LCD TV screen might have been broken down { hardware problems} resulting in black streaks or the formation of Grey or black color on your screen, you will need to get your LCD TV screen undergo some diagnostic procedures before the problem is fixed. This will help you avoid future re-occurrence of the problem.
Thanks for using fixya.....
SOURCE: 42" lg lcd tv pitcher flickers then gos black
Since the audio is still working, the main power supply probably
wasn't at fault and you may be looking at more research and
possibly
more expense.
The problem is very likely on the largest board or with a failing
circuit that is part of the display.
You may be able to isolate it by using 'freeze spray' which you can
buy anywhere electronic parts are sold.
I suggest more than one can of it; ~ $7-8/can.
You will need to have the guts exposed and the set turned on.
Look around the edge of the display itself for chips (ICs) and give
any you see one brief shot of the spray, wait for ~1 minute for it
to
'soak' and then move on to the next one.
If the video comes back, even if only briefly, repeat the cool-down
until you are confident to have found the right one.
If you can isolate it, you still have a problem.
If the sick IC appears to be 'glued' (with solder) onto instead of
through the board, you may not be able to replace it successfully.
If you can see that it has pins going through the board, these can
be
replaced by anyone with a professional soldering tool and a steady
hand.
Remember, the problem can be on a board that is only connected to
the
display panel but if on the panel itself, you may not be able to buy
a
replacement for less money than a new set would cost.
