Refrigerators Logo
a
alexandria Posted on Mar 02, 2015
Power surge caused appliance to go out. refrigerator ice maker now not making ice. has water on but no ice help
After power surge ice maker not working. not sure how to trouble shoot to see if able to reset my self? or need to call for service
shannon morton
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Mar 02, 2015
shannon morton
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
Helped
988
Points
36
Reset the ice maker:
Locate the switch next to the water filter status light.
Press the light switch five times in 10 seconds or less.
Wait for the status light to change from red to green.
Why is ice maker spraying water everywhere inside the freezer?
Make sure the water is coming from the ice maker by using additional light to spot the source of the leak then you possibly have a defective water fill valve leaking water slowly and causing water to freeze where water exits the tube into the ice maker. Once there is ice there and the ice maker calls for water the water either spews all over everything or is blocked from filling the ice maker cube slots altogether. The only repair is to replace your=> Whirlpool Refrigerator Water Inlet Valve W10408179 I'm here on Fixya if you have questions Appliance 911 Sea Breeze Contact Me Here
My GE Side by Side refrigerator stopped making ice and dispensing water.
Check out the solenoids and power to the water solenoids for ice maker and door water.
Compressor will not start on a frigidaire refridgerator
The compressor gets power from compressor capacitor or compressor relay.On some models there is capacitor and on some there is relay.May be that relay or capacitor got shorted causing the problem.
But if that checks out ok,then its faulty compressor causing these.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
1helpful
Hotpoint Side By Side Refrigerator Failing HSS22IFMDWW
Power down power up resets most electronic controls a power fluctuation could have caused the glitch recommend a surge supressor for the wholle house or the type made for appliances no power strips
1helpful
2answers
Ice maker won't make ice won't let water in
Hi and welcome to FixYa. I am Kelly.
Ice makers not making ice are often a symptom of an automatic defrosting problem but first we will check out the ice maker itself.
Download this manual:
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
- Go to page 25 of the manual and determine which of the 2 "optics" designs you have. Then follow the troubleshooting steps. Note the charts on page 32 and 33 can be rotated by rt clicking and then choosing rotate clockwise. Bad thing about this is you have to click rotate 3 more times to to upright all the rest of the document when your done looking at the chart.
- If the Optics test is good proceed to the the ice maker functional test on page 29 and note the jumper wire required
As for the water valve see this link:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
and this picture:
http://www.american-appliance.com/images/image_data/dual_valve_wp_small.jpg
You can make a simple test cord out of a CHEAP extension cord with some bayonet terminal ends and power the solenoids individually after removing the connector of the water valve solenoid. Apply power from an outlet to the solenoid and the powere solenoid should provide water to either water in door or the icemaker itself. 5 seconds is more than enough time to determine if the solenoids are functioning properly.
Between the 2 manuals you should be able to determine if you have an ice maker problem or...
Your symptoms are being caused by the freezer rising above 18 Deg F and the ice maker thermostat is just not cold enough to cause the ice maker to go into the harvest cycle. In this case... there are several other possibilites:
- Defrost control
- Defrost Element
- Bi-metal thermostat (60 Deg)
- Evaporator fan not running at full speed / at all. (A failed door switch can cause this but if the door switch is bad.. you will not have water in door functions also.)
- Dirty condensor coils
- condensor fan not running
Thanks for choosing FixYa,
Kelly
I had a power surge and ever since my ice maker won't fill with water. If I manually pour water in the ice maker, it will dump the ice.
the water pump is burned out.
the power surge most definitely caused this.
locate the water pump and with a multi meter test for power.Replace.
1helpful
We HAD A POWER SURGE NOW FRIDGE WILL NOT SWITCH ON
99% chance that the surge blew the power supply board. If it is a French door, bottom freezer model with ice and water through the left hand top door, it may have taken out the motherboard too. Samsung uses at least two boards, one main motherboard and a power supply board that powers the main.
Whirlpool Gold Ice Maker Quit Working
IF THE FRIDGE IS COOLING AND FREEZING WITHOUT AND HASSLE THEN YOU DONT HAVE A PROBLEM WITH YOUR CONTROL BOARDS.ALSO IF THE WATER IS STILL COMING OUT THE WATER SIDE OF IT.YOU NEED TO LOCATE THE WATER VALVE AND CHECK IF THE VALVE TO THE ICE MAKER IS NOT BLOWN THAT MIGHT BE THE CAUSE OF THE FRIDGE NOT MAKING ICE.
GOOD LUCK.
MOHAMED
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
