Drain pump runs constantly:Error code E02
Suggestions: First see that the exit hose behind your machine is inserted at a particular height, ie about 3 feet above ground level, then into the standpipe in your wall. If things dont work plug off the wall, open up behind, you will see a thin pipe coming down from the pressure switch to the drain area. Disconnect this pipe carefully from the top and blow into it, it should be free. If blocked clear, if broken or damaged change. Refit carefully.
Pl rate me helped.......
