NRS Hoveround MPV 5 - Used Power Wheelchair Logo
C
Claude reynolds Posted on Mar 01, 2015
Light blink chair is in gear - NRS Hoveround MPV 5 - Used Power Wheelchair
Light come on controller no flashing code lights joy stick does not work
The M51 could have the motor clutch levers in the free wheel/push mode and the joystick will not blink if this is the case. Make sure that the chair cannot be pushed. If it can be pushed it means it is in free wheel and you need to lock the motors in gear.
If it is in gear and the joysticks green light does not change color or blink it could be that the joystick is bad. When nothing happens and the lights don't blink when you push the joystick knob the chairs controller basically isn't recognizing the joystick movement.
Time to have the joystick repaired or more. Have a technician look at it.
We put gears on it starts goin then it stops it self
Look at the joystick when the chair stops. The battery level lights should be blinking a certain number of them repeatedly. The lights are a diagnostic code. The number of the battery level lights blinking will tell you if you have a motor, joystick, module or battery problem.
Came off bottom of van ramp tipped a couple inches ant chair tipped won't move but lights on stick fflash ,it is in gear
Sounds like you have loose wire, but I have included a site that will assist you. The link will not work directly sorry. Just copy and paste into your browser. file:///C:/Users/Owner/Downloads/INFINFB2047_Jazzy_Select_Troubleshooting.pdf Note that you must have a PDF reader installed to see this.
Lights on chair keep blinking and won't move
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Lights keep blinking and chair won't move
Yellow lights blink and chair does not move on Jet 3 power chair
Chair no longer charges, no flashing or blinking, lights,
All the lights are blinking very fast
try pushing the chair. If the chair moves your motors are disengaged. to engage your motors look at the base of the chair there should be a lever possibly 2 push, pull or turn depending and try your chair again if you need additional help you can reach me at 404-966-3734 and i can walk you through it
Top NRS Health & Beauty Experts
ADMIN Andrew
ADMIN Andrew
Harsal Patel
Harsal Patel
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
