1981 Power Source - 1983 Kawasaki KZ1000, LTD, CSR Motorcycle High Performance Sealed Battery Logo
Gregory Jackson Posted on Mar 01, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I replace a stator on 1981 csr 250 - 1981 Power Source - 1983 Kawasaki KZ1000, LTD, CSR Motorcycle High Performance Sealed Battery
RAYMONDO1953
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Power Source Expert 545 Answers
  • Posted on Mar 10, 2015
RAYMONDO1953
Power Source Expert
Level 2:
Prodigy:
Answers
545
Questions
Helped
106795
Points
669
Using a standard flywheel puller remove flywheel then unscrew coils
1helpful
Kawasaki Kaze ZX130 - do any body have a workshop manual to this bike?
overflowing while you have it parked? I have a 1981 Kawa CSR 250 and it leaks gas when it is on the kickstand because it leans too far over... I always shut-off the gas when parking and put it up on the stand when I won't be riding it for awhile
Is there a fuel filter on a 1981 csr 1000 and if so how do you change it,bike has 17,700 k on it but has been sitting for 4 years
The float bowls on the carbs are basically your filter-you need to take them off and clean them. Good luck.
What is good replacement spark plug wires for a 1981 kz1000 csr
Most auto electricians carry HT cable and cut lengths off as required. There are bright mauve super grade cables and resistive plastic cables. If you have a healthy coil, there is not much performance difference in any of them, just the price varies.
Make certain the physical size of the cable is the correct size and be guided by the electrician or store salesman's experience. Take a cable with you when you look for new cables and have a good idea how much you need, not forgetting the new plug caps!
Where is the starter located on a 1982 kawasaki csr 1000
Hi. The stater is located on top of the engine under a cover just below the carbs on the left hand side, directly above the gear lever, paul
3answers
I need schematics for a 1981 csr 250 Kawasaki...
clymer or haynes book--try library sec629 others *** manuals are similar-sayonara
I WONNA PUT POD FILTERS ON 1981 CSR 1000 WOULD 52MM BE OK
measure the intake diameter, the pod sizes depend on the size they need to mount to.
If the bike has cv carbs, with the vacumn diaphram that opens the slides, they work better sucking on still air ie: standard box. to see if you have cv carbs twist the throttle, with the engine off and see if the carb slides open. cv carbs rely on intake vacumn to open them
Exhaust system needed
A beautiful place so I hear, my friend.
Is there no after market market (replacement parts) for your Kawasaki in Dublin?
Check here please: http://www.oldbikebarn.com/Street/1981-Kawasaki-KZ1000-C or here http://www.pingelonline.com/exhaust_kawasaki.htm
Thanks for your interest in FixYa.com
1helpful
Oil is in stator area and i wonder if its normal for a kawasaki 250 kz 4cycle motor to do that
Hi and welcome to FixYa,
To my understanding, yes as it lubricates the shaft/bearing and help cool the windings of the stator.
Good luck and thank you for asking FixYa.
Battery not charging Is there a known problem with the stator or Regulator?
I don't of specific problems with Kawa electrics. I assume you have checked the charge voltage across the battery. Get the engine running and measure the voltage at the battery terminals. The voltage should be between 13.5 & 14.5v with engine running. If your meter shows 12v, then the battery is not receiving a charge. I once had this problem on an old Suzi GT380. The fault was caused by an earth wire missing! Make sure the regulator and rectifier are earthed. Assuming all the above is ok then the stator may be burned out. recommend the Haynes Motorcycle Electrical Manual.
Top Power Source Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Power Source Expert? Answer questions, earn points and help others
