There is a switch at the point where the door closes or somewhere around the front of the dryer that the door engages when closed or disengages when the door is opened that has gone bad.
Switch for the door is sticking or bad. It is usually the same switch that turns the light on when the door is opened. I just checked mine, it was sticking a little. I pushed it in as far as possible and sprayed a tiny amount of WD-40. Pushed in and out several times. No more stick. A very light oil might work also. Otherwise you have a bad switch.
