I need to tighten the chassis as it has become loose. Where can i find information to know which bits to tighten?
SOURCE: unrepairable inner tube
True Goo inner tube sealant! Go to a bicycle repair shop with your stroller, and honestly, have all the tires shot up with this goo and then pumped up to your desired firmness...
I have a different jogging stroller, but I know the Maxi Cosi's Mura has the same air pump access as other bicycle tires like my jogger does. I kept getting flats, and this goo has kept my tires firm for 6 years now, I used to have to bring along a pump, but never again after this repair, it plugged up a small leak for one of my tires that kept going flat quickly and keeps the others from the eventual softness that was recurring.
SOURCE: I lost my maxi cosi mura 4 hood, where i can find
I would suggest that you contact www.maxi-cosi.com who should be able to point you in the right direction.
I hope this helps.
SOURCE: How do you fix a flat tyre on a maxi cosi mura?
If you have a puncture and there is only one hole, you can get a puncture repair kit for bikes from somewhere like Halfords and repair the inner tube.
I found the inner tube on one of our tyres was faulty and there were about 20 small holes around the seam. I got a bit fed up with arguing whether or not the guarantee should cover this and so we ended up buying a new inner tube from our local tyre place http://www.etbtyres.co.uk/ it was only £5.
SOURCE: My Maxi cosi stroller rear wheels are becoming
No as they are rubber ones - look for replacement on Website/.
SOURCE: I have a maxi cosi mura and the hood has broken.
Good evening, I have a Maxi Cosi Loola Stroller and one side of the hood snapped off, how can it be repaired?( I still have all the pieces)
