If I hook it up from Receiver out to TV HDMI(arc) No sound, If I hook it up from TV aux HDMI to receiver HDMI input No or any for that matter NO audio!!!! TV is set as manual says but no audio on any channnels
The HDMI connection on the back of the TV is input-only. You can't send audio or video out through it. Use the analog Audio Out connections next to the coax cable connector to send audio to your receiver. Most likely, the audio coming in from your cable service is analog anyway, unless you get a cable HDTV converter box as Lawrence Oravetz suggests. The analog connection would not be that bad; you'll still get the better speakers and greater amplifier headroom of your audio system.
If you have a DVD player with HDMI output, you can run the HDMI cable to the receiver HDMI input, then run another HDMI cable from the receiver HDMI output to the TV HDMI input to get the video. That's the intention in most receiver designs with HDMI connections; the output is intended to relay the video after the audio is picked up.
You'll need to update your cable box with one that has an HDMI out port on it. Nothing else will work.
SOURCE: Vizio SV470XVT will not output Dolby 5.1 from optical out..
TV's only will output 5.1 from HD stations. If you have a DVD player, XBOX 360, etc connected through HDMI, then the TV will only send stereo PCM through the optical out.
SOURCE: I have a VIZIO LED/LCD VF551XVT hooked up to a
I have the same set, same problem with one of my MOTOROLA boxes, but not with another. I have a SONY TV that works fine with this new MOTO box, but the new VIZIO does not. The audio is coming through the HDMI cable just fine, and the fact that it works when you cycle power on your TV means it's the SYNC between the TV and the BOX. I have the identical problem and am taking back the MOTO box for another one. I spoke to VIZIO for about 45 minutes trying different things. They think it's the MOTOROLA box, COX (my cable company) thinks it's this particular box, who knows.
SOURCE: Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
SOURCE: Our 42" Vizio will not display/play sounds when
Hello
One board takes in the HDMI as well as the other signals. Sometimes part of the board breaks and that is what sounds like has happend in your case. This is a fairly common problem and most people tend to just live with it. Others sell thier tv and a few find the number of thier board to see if one is available on ebay or shopjimmy. If you are comfortable with electronics the board is not hard to replace.
Im sorry your HDMI broke....
I hope this helps
SOURCE: I just got this Vizio
Before you go to any more trouble troubleshooting potential hardware and/or connection issues, look at this page of reviews on Dell's site, taking special care to read 'Review 8' by an owner named 'Milwsport'.
Testimonial: "thanks for the quick informative response!"
