Barcode with Prefixed Data Stream Indicator is not able to scan,since the scanner device is missing data stream indicator setup.
SOURCE: Motorola MC3090 do not read barcode starting with zero
look online there are learning barcodes out there you can scan, look for one with zero in front, if you are making the barcodes yourself than put a * at the beginning and end and then make barcode, it will capture everything in between,
SOURCE: Scanner input
Yes, depending what sofware you are using. Let me know and I can provide steps necessary for this request. You can always contact me directly [email protected] or 630-622-2024 toll free 866-271-9891 Ask for Andrew
To the best of my recollection--there is no data stream indicator setup for that series of scanner. Unfortunately, you may be forced to somehow separate the "prefixed data stream", from the barcode--in order to be able to scan.
