Dishwashers Logo
A
Anonymous Posted on Feb 27, 2015
I just installed a new bosch dishwasher we installed it water is going in to maschine we had a electrical outage now i have an e15
Vitally Alcher
Level 3:
  • Master 1,645 Answers
  • Posted on Feb 27, 2015
Vitally Alcher
Master
Level 3:
Answers
1645
Questions
Helped
467395
Points
3209
Disconect from breaker one hour
My Bosch dishwasher has a E15 Error.
This is a flood sensor issue rather than a float switch issue. The sensor is in the tray and senses water from dripping hoses or worn pump seals. It doesn't need much water as the sensor is at the lowest point, so it only needs a teaspoon of water. you can check the connections at sensor end and follow it to the control board connector.
My Bosch Dishwasher is displaying an error code E15, what does it mean? An E15 error code indicates that the safety switch has detected water in the base of the dishwasher. Your leakage protection system has activated.
E15 Bosch Dishwasher Error Code
Videos as well with fixes
https://www.google.com/search?q=bosch+dishwasher+has+a+E15
Bosch dishwasher rinse aid and check water light flashing.
First you have to fix where the leak is coming from that tripped to E15 error code. You can reset by turning off power for 15 minutes.
An E15 error code indicates that the safety switch has detected water in the base of the dishwasher. Your leakage protection system has activated. What can I do to fix the E15 Error Code on my dishwasher?
.https://www.google.com/search?q=dishwasher+e15+error
Bosch dishwasher shows an error message E15. Any suggestions on how to resolve the issue. We've cleared the E15 several times by tilting unit and removing water, but seems to reappear
E15 is a leak into dishwasher base. Leak can be as simple as using to much soap powder or a split lower spray arm to more expensive fix of a leaking sump base or wash pump. Need to pull dishwasher out of cavity, remove side panels and front kick panel and run machine and watch base to see where leak is coming from. Have had them leak from 4 main places. Heat exchanger where large plastic nut screws from inside. Bottom of wash pump. Plastic sump base (mainly towards front of machine. And last place is a small pin hole can develop in stainless base of machine towards front of dishwasher. Check soap usage and lower spray arm for splits first.
1helpful
Bosch diswasher e15 light
Most likely it is the flood switch trigger causing the problem.
Many reasons for this but mainly it means there could be water leaked into the base of dishwasher where flood switch is located.
Or if you have Aquastop fitted in the water inlet hose then the hose might have kinked due to age or being pressed between cabinet wall and dishwasher. Turn power off to dishwasher at mains plug and pull it out. Check hoses. Tilt it about 20 degrees to one side on a towel and hold for about 10 secs. This should get the water out. Wait an hour or so to dry any moisture in the base and then plug back in and turn on. This should reset the E15 fault.
1helpful
Showing fault E15
I'm going to assume this is an SMS GV640 bosch, E15 indicates there is water in the base under the tank and therefore a leak. Pull the front of the machine onto a towel and pivot the whole machine forward (ie lift the back off the floor at about 45 degrees). If you see water flow from under the machine, you have a leak. You may find the the machine will now seem to work, but you will have to trace the leak or it will activate the flood device and give you E15 again.
1helpful
Code E15 bosch super silence dishwasher
Use dish washing rug and soak water out trough salt inlet. Only 10 degrees tilt needed. Boch Super Silent dishwasher. E15 error code.
Mar 02, 2013 • Dishwashers
Whats E15 on my bosh exxcell dishwasher-totaly baffeled,help please
go to read the instruction manual carefully, the only that you can clear the error is in section troubleshooting.
if you do not have go for free download: www.fitness.manualsonline.com
God bless you
11helpful
The control panel on my dishwasher is showing a tap and E15
Mine's a bosch, same problem but started with E25 due to broken glass in the pump impeller, after struggling to remove it and then testing, it eventually moved to E15 as rightly so, no water was entering the machine due to the E25 code. The advice above is good, but take the device out first and tip the machine. This cured my faults without the need for a service call or spare parts.
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
