Good chance your Gfi is on verge of failure I had one, took long time for me, yes me to figure it out. Replacement may solve problem. Double check, have you added other appliances on the same circuit? GFI will pop when other appliances are on the same circuit. For example two coffee makers on same time same GFI and similar issues. Otherwise may have a problem with the ice maker voltage leaking somewhere. If GFI replacement doesn't help. Do you still have warranty on Icemaker? If so follow that. If not contact Ge anyway. Recalls maybe "hidden".
