ALL loads stop because of UNBALANCED LOAD ERROR - UE. The loads are NOT too small. Loads are NOT a heavy/light load mix. Loads are redistributed but STILL show UNBALANCED LOAD ERROR - UE.
I think there was a software fix for this model. Known issue. Contact LG.
The following tips might help you in resolving issue:
Add a few items to distribute the weight.
Reduce Spin Speed to Low or No Spin on Small Loads.
Manually redistribute the load.
Use Bulky/Large Cycle for such items as rugs, comforters, sheets, blankets and pillows.
After applying these steps if still error is displayed then use Lg WT5070CW Manual for advanced troubleshoot setup.
https://guideusermanual.com/product-name-wt5070cw-manual&po=109150&lang=English
1st check ur floor level if the floor level is not flat means sure the error will come.. and dont put a blanket with other clothes
SOURCE: unbalanced load error
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer ID doesn't mean
much to me. It's been about 55 years since I had
experience with front load washers. However I can
suggest you go to www.applianceaid.com where
they have very good trouble shooting and repair
information on front loaders. I think you'll find what
you need there. Good luck with it.
SOURCE: LG WM2077CW (UE error code)
For "ue" an unbalanced load is sensed three times; re-adjust your load in the machine. What is the capacity of your machine, you could weigh your dry clothes........refer manual.
For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
.....& rate me if helped.
SOURCE: BRand new installation of 1 year old machine we
hi,
I am a novice at front loaders but it sounds like it needs new suspension parts, namely springs, sounds like the machine had a hard life before you got it. since its used anyways it cant hurt to take the back off and see and study how it works and how the drums suspension works. you can try to find the springs at an appliance store. Im not sure if you can get springs directly from LG. LG's are a pretty good name brand, probably worth fixing..
good luck!
jm
Testimonial: "we would have done this - and this confirms our plan! thanks! "
SOURCE: Unbalanced load, sign UE is on, cannot open the door
UE:
• The load is too small.
• The appliance is tilted.
• Laundry is gathered to one side.
• Non distributable things are put into the drum.
See page 17
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: My lg Tromm front load
these units have had alot of problems especially if it is on a pedistal ...they won't admit this is a problem but i have been a lg servicer for over 4 years now and see it everyday ...the unit has a stator on the rear of the tub and on the stator is a device called a hall sensor that goes bad very often... it is what controls the spped and balance of the tub..if the load starts getting unbalanced the hall sensor will tell the motor controller to slow the speed down... most likely this is your problem.... good luck please vote
This error code indicates that an unbalanced load is detected.
Click the following to learn more about unbalanced loads in the BravosTM washers. The example is for an impeller washer but is applicable to washers with agitators.
Is the wash load balanced? If the load is unbalanced, the washer will display this code while attempting to balance the load at the end of the wash cycle and before the final spin. If the code remains and the wash cycle dial is flashing after the recovery routine has stopped, open lid and redistribute the load. Close lid and press Start/Pause. Is the washer level? Does the washer rock when pushed against the corners? If the washer is not level, the washer may be more sensitive to unbalanced loads. The washer must be level from side to side and from front to back. The front and rear feet must be in firm contact with the floor. Make sure the locknuts are tightened. See the Installation Instructions for details. To remove the error display, press Power/Cancel or Pause/Cancel once.
