5x-y=-5 answer x=-1, y= 5
http://www.wolframalpha.com/input/?i=Determine+the+x+and+y+intercept+of+the+graph+for+equation%3A+5x-y%3D-5
-3x+2y=7 answer x = -7/3, y = 7/2
http://www.wolframalpha.com/input/?i=Determine+the+x+and+y+intercept+of+the+graph+for+equation%3A+-3x%2B2y%3D7
SOURCE: How do I graph an equation such as y= 5x + 2?
Turn calculator ON. If you do not see several icons press [MENu].
Use arrow to select the [GRAPH] application and press [EXE].
In the entry screen, the line with Y1= is highlighted. If it is not, use arrow to highlight it.
Press the right arrow, the highlighting disappears leaving you with Y1= and the blinking cursor.
At the position of the cursor enter 5 [X, theta,T] key under the [ALPHA]. On the screen appears 5X, complete you equation +2.
Press [EXE] to store function.
If you want to draw other functions, it is time to do so on that screen.
When done press [F6:Draw}.
If the screen does not show a lot of the function, you can use the arrow keys to pan the graph.
You can also press [SHIFT][V-Window] to set the window limits.
Hope it helps.
Testimonial: "Thank you so much!!!"
SOURCE: How do I solve a polynomial equation:
Sorry, but what you wrote is not an equation but a polynomial expression. You want to solve the equation x^4+5x^3-3x^2-43x-60 =0.
The solve( command, can only be used with real numbers.
The solve( is available through the CATALOG :
[2nd][CATALOG], scroll down till you reach the command. Highlight it
and press [ENTER]. The command echodes on main screen as solve( .
You
complete the command by entering the expression (not the equation), the
name of the variable you solve for, the initial guess , and { lower
limit, upper limit} between curly brackets, and the closing parenthesis.
Exemple:
solve (x^4+5x^3-3x^2-43x-60 , x,0 {-5,0} ) [ENTER]
should give you the negative root,
solve (x^4+5x^3-3x^2-43x-60 , x,0 {0,5} ) [ENTER]
should give you the positive root.
It
is implied that the expression is 0, so you should not
insert =0, otherwise you get an error. Here for the lower limit is -5 you
must use the change sign symbol (-) under the 3 key, not the regular
MINUS.
You may ask how I knew that there were two roots when the equation is a quartic? By first graphing it to have an idea about where the roots lie and how many there are. You should always do that to speed up the search.
There is another way to zoom in on the roots: by drawing the graph and using the tools accessible under the [2nd][CALC] menu, namely the option [2:Zero]
The resolution of the TI83/84 is not good enough for this function that grows too fast, but I am inserting a picture of the curve from another calculator with a much better resolution.
Hope it helps.
SOURCE: how to put letters in calculator from an equation.
Use the âLPHA key followed by the letter you want. The letter is written on the body of calculator in the same color as that of the ALPHA key (Green).
