U-Line 75R Refrigerator Logo
A
Anonymous Posted on Feb 22, 2015
Will not get colder than 50 - U-Line 75R Refrigerator
Stephen
Level 2:
Habit-Forming:
  • Expert 188 Answers
  • Posted on Feb 22, 2015
 Stephen
Expert
Level 2:
Habit-Forming:
Answers
188
Questions
Helped
74464
Points
489
The first thing to check would be the condenser coils. Not sure where it is on your model, but when they collect dust, they do not allow the fridge to cool down correctly. It will be on the back of the fridge. Either running down from top to bottom or will be at the back behind the lower panel. If the condenser fan is running, then the coil is probably dirty. Unless someone has accidentally moved the temperature setting inside the fridge.
Should i use dex cool or 50/50 mix in alero
You should use what ever color is in there. But they do make , what they call a global mix (usually green) that can be mixed with all other colors of anti freeze. 50/50 mix gives you protection down to -20 degrees. If you live in a colder area, use straight antifreeze.
1994 Pathfinder wont start in colder weather
Test engine coolant temperature sensor not registering a cold engine. this is a two wire sensor with a wire retainer holding connector on.
Can you put an engine block heater on a 2004 f-150 non-heritage model fx4
block heater mostly for diesel engines.living colder climates use 5W - 30 ENGINE OIL make sure you 50/50 coolant and water mixture or add little more coolant if you live in zero temperatures have strong good cold cranking AMP battery cold start ups should be no problem.add fuel treatment to fuel to keep out water.
2answers
What colour anitfreeze do I need
eythelene glycol ,is transparant in its natural form so the colour is un-important ,so long as you have antifreeze in the system to prevent corrision it doesnt matter
Overheating,replaced all hoses,new radiator,
Ok if you do not check the engine loses antifreeze works well when you start or turn on uneven, check if the fan is working you bien.Thanks
1helpful
2answers
Freezer works great, but fridg. will not get below 50
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Danby Propane Refrig-- Low Cooling Output
good day,
hope this link below will solve your problem.
ref
Motor running about 210 deg would like to see it run 180 what do i need to do
210 degrees is exactly where it should run. If colder, the computer will start throwing more fuel into the engine. (system is calibrated at 210) As long as the antifreeze mix is maintained at 50/50 you will not overheat or have any other problems!
1helpful
2helpful
Type of engine coolant for 1998 ford taurus
You can use any name brand coolant to include the 50/50 premix type, The colder the environment you live in, the higher percentage of glycol you want to have.....in other words.....if you live in the south, you can run the 50/50 mix year round. If you live in the north, you would want to follow the manufacturers suggestion.
Top U-Line Refrigerators Experts
Kardoc
Jorgie  the...
Jorgie the...
ADMIN Andrew
ADMIN Andrew
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
