Is the leak on the same side as the hinges? If yes I'm guessing someone overstressed the hinge when opening the door too widely or by leaning on the open door and the seal is just barely tight enough now. Crack the door open half an inch and eyeball the door gap from top to bottom on the open side to see if the door is unevenly hinged - you can use a ruler to help measure but you need to keep the door immobile while comparing top and bottom gap widths. Tape a hard wedge in place in the doorframe to help with that. Fix for that? Pressure on the door in the right direction to straighten the hinge mount.
We have the same problem with our LG washer. Don't think the door can be adjusted but I'm not for sure. I think the gasket is wore out but haven't checked on fixing the problem yet because it barely leaks.
The water should be able to come up to the door level without leaking. Chances are you have build up on the bottom side of the glass on your door. If so take a razor blade and scrape the build up off. Your door will quit leaking.
These are notorious for the door boot leaking. Look for any tears, rips, pinholes in the door boot. Also make sure the door is parallel with the machine. Most likely it's the boot. Parts about 100.00. Labor can run from 110-140 depending where you go.
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Carefully look at the door gasket to see if any irregularity in seal. Could be problem with door seal; or you could easily change door mechanism thru a spare part shop quoting your model and spare-part No or "door mechanism"
