Nokia E61 Smartphone Logo
Anonymous Posted on Jul 08, 2009
Nokia E61 Wifi connection
I dont know anything about how to connect my e61 with wifi!! :(
i m using sky broadband. my e61 locates the wifi but doesnt connect to net. can somebody please write down all the steps for connecting it to internet!! i wud be gratefull to any of ur response!!
Anonymous
Level 2:
  • Expert 50 Answers
  • Posted on Jul 08, 2009
Anonymous
Expert
Level 2:
Answers
50
Questions
0
Helped
20900
Points
188
Setup Internet access point for WLAN menu>tool>settings>connections>access points select options>new access points Enter Connection name Data bearer: select Wireless LAN WLAN network name: select search wlan to select wlan in range. network status: select "public" if you can see wlan in range WLAN network mode: select infrs or adhoc WLAN security mode: select same settings used by WLAN access point WLAN security settings: Homepage: select the homepage you want
now you can connect & browse the internet. hope this helps
  • Hamza Talbi
    Hamza Talbi Oct 28, 2013
    (no gateway reply ) ??????????
Hamza Talbi
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 28, 2013
Hamza Talbi
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1434
Points
How can i use WiFi to download apps,music,etc on my Nokia Asha 210
first of all you should have a broadband connection which comes through wifi enable router through which you are going to connect your phone to internet then you need to go to your phone wifi and turn it on select your wifi(ssid) name type your wifi password and then go to browser to download anything .
2answers
Starting problem and wifi problem
Try to Install the latest driver.
Jun 14, 2017 • Nokia E61
Dont know how to connect to internet
If you want to connect to internet there are different ways on how to do it.
  1. The first one is to have a wireless broadband modem that you will use to gain signal and access the internet.
  2. The second one is to find a Free Wifi Zone where you can access the internet using you Laptop wifi. (This is what i suggest you must do, so that you dont have to spend money to access the internet) but some wifi zone are password protected so be sure to find a open shared wifi.
  3. The third one to apply for dsl /lan connected internet that uses ethernet wires that will be connected from the modem to your wifi in able to gain access to internet.
Hope i Help..
1helpful
I m a new user of htc s620. i dont know how to use wifi conection on it . i saw more videos on youtube but their programe was not in my phone and is the wifi conection works in pakistan? thank u
The wifi connection on your htc phone can be accessed by going to the connection settings which is located under the phone settings on your S620.you will see the option which says turn on wifi in the sub menu under the wifi,simply click on turn on,and you are good to go.
The wifi connection will only work in a location where there is broadband internet connection network which is shared and can be accesed by wifi,which is irespective of the country.
When you turn on the wifi connection on your phone,it automatically scans for available networks and you will be prompted to connect to any of the available networks it recognizes,but if it doesn't get any available network it means there is no wifi connection in the location you are situated.
Thanks and Good luck!!!!
1helpful
Hi, please can you tell me how can i make a p...
please helpme. i connect a wlan wifi .but not connected.
network connection is failed the message is come
1helpful
NOKIA E63!!HELP PLZZZ
it can be, but for you to have it, go to the nokia company and register first a Wi Fi program in order for you to enjoy wifi
2helpful
Installing a theme in nokia e61?
To install themes, and other applications, onto the Nokia E61 you will need
to download and install Nokia PC Suite on your computer. The program is
free and available on the Nokia Web site.
Once the program is installed the cellphone must be connected to the
computer through a cable, Bluetooth, or infrared connection. The PC
Suite program will guide you through the process. A cable connection
is the fastest.
PC Suite has an application installation manager. Use it to install
any themes or Symbian 60 programs you have downloaded. Once
the theme is loaded on the cellphone, use Menu > Tools > Themes
to find the theme name. Click on it and the phone will ask whether
you want to preview the theme or actually install it.
2answers
Sending and Replying messages
You should download the patch from the Nokia Europe website for SMS for the E61. This is recommended for all users, as it will significantly increase the speed of sending messages. Vir
Top Nokia Computers & Internet Experts
k24674
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
