Refrigerators Logo
A
Anonymous Posted on Feb 18, 2015
What does an O F fault code mean on a frigidaire refrigerator mean
pwrsce
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 63 Answers
  • Posted on Feb 20, 2015
pwrsce
Expert
Level 2:
Cheetah:
Answers
63
Questions
0
Helped
20957
Points
102
Sounds like off to me. An open sensor will be displayed in either the ff display or the freezer display. if it is an open freezer sensor it will display in the freezer display. A communication failure will show as a SY CF, and a communication error will display a SY CE.
  • pwrsce Feb 20, 2015
    O will be diplayed if it is an open sensor.
1 Related Answer
chrispolkele
Electrolux
  • 4342 Answers
  • Posted on Jul 30, 2012
Our people make the difference
    Verified Fixya Pro
    SOURCE: Model LGHC2342LE1 Frigidaire refrigerator fault code SYCF. What does it mean?
    It is a communication failure. Check wiring between MainControl Board and User Interface Board. Replace User Interface Board. Ifproblem still exist, replace Main Control Board.
    Frigidair range I would like to know what f11 means
    Hello, Floyd -
    Without knowing the model of your Frigidaire range, I cannot look for the owner's manual for your particular model and find what F11 (a fault code) means for your specific appliance.
    However, I did find a web page listing fault codes for newer Frigidaire ranges. See the information here:
    http://www.applianceaid.com/newer-frigidaire-fault-codes.php
    From that information, the EOC (Electronic Oven Control) may need replacing.
    What do error code F1 and F2 mean specifically.
    I have never heard of a fridgidaire cell phone,when did they start making cell phones that have sensors?
    If you want a correct answer,then you need to start off with the correct info,your question will be overlooked because our experts have no clue what you are talking about and then you would complain or mark our answer as not helpful,when in fact,it was your question that was misleading.
    F1 Defect of the circuit board
    http://www.repairclinic.com/Shop-For-Parts/a4b2/Frigidaire-Refrigerator-Parts
    FRIGIDAIRE Error Codes Fault Codes
    May 31, 2015 • Cell Phones
    3helpful
    3answers
    What does the error code 5y EF mean on my Frigidaire refrigerator
    Good Morning Friend,
    I understand you are receiving an "SY EF" code on your Frigidaire refrigerator, model# FRS3R5EMB. The "SY EF" code stands for system error with the evaporator fan. This possibly means that there is something going on with your evaporator fan or it could possibly be a false error code. . I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
    2helpful
    What does frigidaire GLES389EQA fault code f14 mean?
    Good Afternoon James,
    I understand your Frigidaire range, model#GLES389EQA, is receiving an F14 fault code and you want to know what it means. The F14 fault code means there is a miscommunication between the display board and the touch panel. I suggest resetting your appliance, by shutting the power of at your home's circuit breaker, for 3-5 minutes. Once power is restored, you will need to set the clock before moving forward. Once the clock is set start the cycle that gave you the F14 code. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
    10helpful
    What does "Sy EF" mean on dispenser led?
    Error Code SY EF is the System Evaporator Fault.
    This usually means there is NOT enough air flow over the sensor, this can mean a faulty sensor, or fan.
    Above is the latest service sheet to do with your machine, you need to check this.
    Hope this helps (remember to rate and commnent this)..
    2helpful
    2answers
    Does anyone know what sy ef means on my new Frigidaire refrigerator means?
    http://www.retrevo.com/support/Frigidaire-FPHS2387KF-Refrigerators-manual/id/23613ag220/t/2/
    Above is a link for your user manual. to download. copy past to browser.
    manuals.frigidaire.com/prodinfo_pdf/Anderson/240389644.pdf
    Above is the latest service sheet to do with your machine.
    That SY ER is the SYtem EvapoRator Fault. This usually means there is NOT enough air flow over the sensor, this can mean a faulty sensor, or fan.. you need to check.
    In my professional opinion you should get a service tech to call, contact your head or local Frigidaire offic, and ask them for a referral to an authorized service agent. When there then ask for a "Quote" as to the repair, this way you can make an informed decision.
    usually though a repair such as this shouldn't be too costly, however it may just be the tip of an underlying condition, which is why i suggested the professional.
    22helpful
    Frigidaire side by side error code 4
    I have Fridaire refrigerator model PLHS67EGSB5 and have electronic control flashing code 4 at the right side (Refrigerator side) . What that means and how can solve it.
    Thanks, Anibal
    Top Frigidaire Refrigerators Experts
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
