Question about Ge Medical Systems Ge Marquette Mac 1200 Interpretive Ecg
How do i enter the mac 1200 service mode?
Enter service mode for biomed techs
    Habit-Forming:
    New Friend:
  • 46 Answers
6ya staff
SOURCE:
Pick up roller
4.1.4 Tech Mode
In service (tech) mode, the technician can check the machine and perform various test to isolate the cause of
a malfunction. While in Tech mode, the machine still performs all normal operations.
To enter the Tech Mode
To enter the Tech Mode, press "Menu + Back + Left + Right + OK + Stop + Menu" in sequence, and the
LCD briefly displays 'Tech Mode', the machine has entered service tech mode.
After entering the tech mode, select the item you want by using a button on control panel.
Scroll to Pickup roller.
I cannot see what comes up on the screen after this but I imagine it will ask if you wan to reset this counter. Press ok and that should do it. You may need to power down but I don't know.
Good luck.
I cannot see what it says on the lcd after this but I imagine
Jan 27, 2014 | Samsung CLP-620ND Color Laser Printer -...
Minolta Error code C0500
1. Test Mode Operations
• The Test Mode is performed from the copier’s Tech. Rep. Mode.
1-1. Entering the Tech. Rep. Mode
1. Press the Utility key.
2. Touch [Total Check].
3. Press the following keys in order: Stop → 0 → 0
→ Stop → 0 → 1.
NOTE
Be sure to keep the display procedure for the Tech.
Rep. Mode from any unauthorized persons not
involved with service operations.
4344S504CA
link to a service manual that explains tech mode
Dec 02, 2007 | Konica Minolta DiALTA Di200 Copier
How enter service menu in ricoh aficio fx16
Press the following buttons into the next order :
press MENU, then press # , then press 1-9-3-4
The LCD screen will show TECH .
Now you are in service mode.
For to change the " Dial Mode " after entering into " TECH " Mode you will need to enter " Data Setup " and then " Dial Mode " and the you can change it from " PULSE " into " TONE " mode.
Do this procedure to go back to user mode :
Press MENU , then press # , then press 1-9-3-4
Oct 16, 2013 | Ricoh Aficio Office Equipment & Supplies
Service manuals I work in a small hospital and we
hi,
if you can provide your email id then i will sent you the service manual for Mac 1200 ecg. Its not possible to upload the service manual here . Its in pdf format.
Ajin
Aug 11, 2013 | Ge Medical Systems Ge Healthcare Mac 1200...
Our MAC 1200 ekg machine prints out 1 empty sheet prior to printing the actual ekg. Is there a way to eliminate that first page? It wastes a ton of paper. thanks, Dan
hi,
1.Press the setup Button
2.Select operating mode and press enter.
3. Repatedly perss the down arrow until it reaches to the "START AT QUEUE MARK" and perss enter. Then select NO and press enter ( if it is selected Yes then before each recording the recorder advance the paper to the beginning of the next page)
4. Press the Start button to exit the setup.
From the next EKG it will print from the first page.
ok
Aug 09, 2011 | Ge Medical Systems Ge Marquette Mac 1200...
How do you reset image unit counter on Xerox Phaser 6110MFP
1. Enter Service Mode by pressing [MENU] [#] [1] [9] [3] [4]
2. If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press Enter
6. Enter Password 1934
7. Arrow to desired counter and press Enter.
The display will show Clearing Counts and then return you to the Tech Menu. Press exit several times to exit the Tech Menu and then power cycle the printer.
Feb 01, 2011 | Office Equipment & Supplies
How to enter ''service mode'' on Aficio SP C221SF Color MFP
this is priveledged information and kept away from non service personnel to protect both you and the device from unqualified access and possible damage.
if you have an issue that requires entering service mode please call for a ricoh tech this ensures that you are protecting the investment you have made in purchasing a ricoh device.
Jul 07, 2009 | Ricoh SP C221SF Aficio Printer
Compatible with Mac?
I have the same problem.  Did you find a solution or just return it?
Jul 21, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Ge Medical Systems Ge Marquette Mac 1200 Interpretive Ecg Logo
965 people viewed this question
Top Ge Medical Systems Medical Experts
Gene Pitts
Marcos Gonzalez
Marcos Gonzalez
Level 1 Expert
Vuk B
Are you a Ge Medical Systems Medical Expert? Answer questions, earn points and help others
