The error code you are seeing means that the Pressure switch is stuck and it cant tell how full the washer is so the unit stops and flashes all lights to warn you. You need to have the pressure switch replaced.
Check the main p.c board inside bottom of machine. Mostly small capacitors in pc boards get damage and our of work due to always switched to main power. If You have some tools you can open it and check capacitors surfaces, you can easily change it if you have some soldering experience... Thank you...
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
May be the switch is loose try fixing it with ascrew driver or the rubber hose is not fixed properly and the machine pump is taking air or the pump failure
Just sorted this problem out, wife said just b4 leaving for work,oh love the door on the washing machine wont open and theres a red light on,,OMG i thought, as she said she would find the instructions when she gets home, so i got the corless drill out and a big hammer,( not needed,) lol just turned the power off and after 2 mins the door unlocked and was able to get all the clean wifes undearware out, cheers all and hope this helps
unplug it for a few minutes and plug it back in again might be a pain but till you can get it serviced it should delete the fault code and run thru a full cycle. hope this helps a little. Not a true fix just a work around.
