Husqvarna Master
- Posted on Feb 18, 2015
Re: How do i replace drive belt on husqvarna zero turn...
To replace EZT belt
Park the mower on a level surface. Engage the park brake.
EZT belt removal
NOTE: Be careful not to damage the fan blades on the EZT as this can affect cooling or damage the EZT.
- Remove the deck belt
- Create slack in the belt by pushing the spring loaded idler arm away from the belt.
- Rotate arm to release belt tension.
- The belt should now be able to be removed from the engine pulley and EZT pulleys.
Belt installation
- Wrap the EZT belt around the EZT pulleys.
- Wrap the belt around the engine pulley.
- Route the belt around the inside of the idler pulley while keeping tension off the belt and then slowly the idler assembly afterwards.
- Check that the belt is on all the pulleys correctly and test drive your unit.
- Afterward then re-install your mower deck once your are satisfied with the drive installation..
