Hey I have a Sansa E280 and my problem is that the wheel used to change volume and scroll through songs, etc. is not working. I have had the Sansa for about 2 years now and have used the heck out of it, so I need to know is it something easily fixed or is it just worn out? Also, it will work just barely every once in a while but only for a few seconds. Thanks for any help!
SOURCE: delete songs from sansa e280
Open up your windows media player and click on the sync tab..your device should be listed there..and also it will show you all the songs you have in there...or you can just format the whole player..formatting will erase everything in that player...
SOURCE: wheel of my sansa is so sensitive
Hi There,
You need to do the following. I did it to mine yesterday and it's great!
http://joustin.com/?page_id=10
One of the major warnings Apple includes with all of its iPods is the permanent hearing damage that could occur if you have the volume on your iPod turned up too high.
To help combat the problem, the iPod comes with a feature that allows you to set a maximum volume level that your iPod can be played at that level is controlled by a combination that can keep others namely children from turning the volume up to dangerous levels.
The good news is, if that combination falls into the wrong hands, it can be reset.
Use your iPod's click wheel to scroll down to "Settings."
Press the center button located in the middle of the click wheel to select the settings menu.
Scroll down to "Playback" and press the center button to select it.
Scroll to "Volume Limit" and press the center button to select it.
Use the click wheel to scroll to the first number of the old combination and press the center button to select it.
Repeat this process for all four numbers of the old combination.
Use the click wheel to scroll to where you want the maximum volume to be set and press the center button.
Use the click wheel to scroll to "Lock" and press the center button.
Use the click wheel to enter the first number of the new combination when the message "Enter New Combination" appears on the screen repeat the process for the three remaining numbers.
Once the four numbers have been entered, your iPod's maximum volume will be set and your password will be changed.
hope this helps
hope this helps
